Two controllers same network
Posted: Mon Dec 09, 2013 7:45 am
by ganjero
Is it possible to have two controller running in the same network with WIFI? would you have to create a second id to use portal?
Re: Two controllers same network
Posted: Mon Dec 09, 2013 7:52 am
by Piper
Should be no problem. You will just need to give one of the adapters a different port to use other than the default 2000.
~Charlie
Posted: Mon Dec 09, 2013 9:37 am
by Piper
One thing I didn't think about was the portal. You would need to set up two profiles on the forum in order to get the portal to work for both RAs.
Posted: Mon Mar 03, 2014 11:11 pm
by bfeik
ganjero wrote:Is it possible to have two controller running in the same network with WIFI? would you have to create a second id to use portal?
How did this work out for you. Id like to do the same thing??
Posted: Wed Mar 05, 2014 7:40 am
by binder
I have multiple ra's on the same network and it works just fine. I do know of at least 1 person on the forum that has 2 accounts so he can have 2 ra's displayed in the portal. his complaint was having to log out and back in with the different usernames to view the data in the portal.
Sent from my Moto X
Posted: Sun Apr 06, 2014 4:55 pm
by Elevatorguy1
