WP25 not working on cable
Toolboy
Post by Toolboy »
Hi
So obviously i stuffed up royaly somewhere in the wizard to get the 2x WP25 to run, cause they aint coming on at all. Also did the upgrade to RA+ :D
Anybody want to take a look and tell me where I stuffed up
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit | Port7Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.DayLights( Port2 );
ReefAngel.StandardATO( Port3 );
ReefAngel.Relay.DelayedOn( Port7 );
ReefAngel.PWM.Channel0PWMSlope();
ReefAngel.PWM.Channel1PWMSlope();
ReefAngel.PWM.Channel2PWMSlope();
ReefAngel.PWM.Channel3PWMSlope();
ReefAngel.PWM.Channel4PWMSlope();
ReefAngel.PWM.Channel5PWMSlope();
ReefAngel.Portal( "Toolboy" );
Re: WP25 not working on cable
Maybe your relay box doesn't have the booster.
Older relay boxes required a PWM booster. It was an optional feature in the past that became standard at one point.
The only way to find out is opening the relay box and checking for the board revision. If you can't find, post a pic.
Toolboy
Post by Toolboy »
The box looks good.
What mode are you running and what speed?
Use joystick to move to the DC pump screen.
Toolboy
Post by Toolboy »
Running Nutrient export mode
No, you are not.
You never initialized the internal memory.
Either upload a wizard generated internal memory, or update those memory location with Portal or android
Toolboy
Post by Toolboy »
Sorry being a dumbass. but I dont know how to update the memory locations with my android
This is what I did when I was setting it up
Port 5 is where the WP25 are powered from
and this is what i did on dc pumps
In this case, I would recommend you using hard coded settings instead of internal memory.
Toolboy
Post by Toolboy »
but wont I then loose functionality of changes values from my phone
You just said you don't know how to do it.
If you know how to change settings with your phone, then your code looks good and all you need is to assign a value to the DC pump memory locations
Ah, I realized after posting that we don't have labels in the android app yet.
Use custom location.
337 is mode, 338 is speed and 339 is duration
Toolboy
Post by Toolboy »
Okay as said before im a dumbass especially when it comes to programming and understanding arduino but I redid the wizard and uploaded and got a screen on my RA about memory updated and that I can now upload my ino. So I hit the generate and upload button again. Now everything works. Dont know how dont know why, but grateful
Toolboy
Post by Toolboy »
Roburto dont know how often you get thanked, but going to take this opportunity. Thank you.
If anyone ever asks me why go RA my answer will be SUPPORT. Try get support from any other controller at 21:40 I dare you
rimai wrote:Ah, I realized after posting that we don't have labels in the android app yet.
guess I had better update the list of locations.
Sent from my Moto X
