Water level expansion as skimmer overflow protection?
Posted: Wed Dec 11, 2013 1:20 am
by Pny
Anyone using the water level expansion as skimmer overflow protection, and can share their idea? Is it possible, and a good way of doing it?
Re: Water level expansion as skimmer overflow protection?
Posted: Wed Dec 11, 2013 4:19 am
by Sebyte
Posted: Wed Dec 11, 2013 4:27 am
by Pny
Yes, certainly... But that wasn't the question.
I think the the water level sensor is both easier to clean and also less prone to false trig by the foam in the skimmer cup...
(There is of course a cost aspect also, with the float switch being cheaper... but since I make my water level sensor boards myself, I will have a few boards left over anyway...)
Posted: Wed Dec 11, 2013 5:35 am
I have a skimmate locker from avast marine which has the pressure switch. One day when I get the multilevel sensor i will replace the pressure switch with one...does that count?
Posted: Wed Dec 11, 2013 5:22 pm
by Piper
I've been contemplating doing the same thing. The problem I ran into was that there wasn't enough room between the inner tube and the outer tube in the collection cup to reliably mount a water level tube. I just picked up a new skimmer with a little more room to work with but haven't had the spare time to dig back into it.
After the first unsuccessful attempt, I was leaning towards float switches though.
~Piper
