Page 1 of 2
Slow down waves at night
Posted: Mon Nov 07, 2011 9:19 pm
by jsclownfish
I'm trying to figure out how to reduce wave flow at night. I wanted to switch from alternating 200 sec waves during the day to shorter bursts with a lull in between at night. I started with this from pieces of other code I found around here, but the seated "if" statements don't fly. Thanks for your help.
-Jon
    ReefAngel.FeedingModePorts = B00110000;
    ReefAngel.WaterChangePorts = B10110000;
    ReefAngel.OverheatShutoffPorts = B00000111;
    ReefAngel.LightsOnPorts = B00001100;
    ReefAngel.Relay.On(Port5);
    ReefAngel.Timer[1].SetInterval(InternalMemory.WM1Timer_read());
    ReefAngel.Timer[1].Start();
    ReefAngel.Relay.On(Port7);
    // Specific functions
    //1st Heater at 78.8, 2nd Heater at 77.0, MH on at 10AM off at 8PM, Actinics on at 9AM off at 9PM, Fan kicks on at 82.0
    ReefAngel.StandardHeater(Port1,788,792);
    ReefAngel.StandardHeater(Port2,770,792);
    ReefAngel.MHLights(Port3,10,0,20,0,5);
    ReefAngel.StandardLights(Port4,9,0,21,0);
    ReefAngel.StandardFan(Port8,792,820);
   // Wavemaker Code with night option
   if (ReefAngel.Timer[1].IsTriggered() )
   if ( ((hour() >= 22) || (hour() <= 8)) //from 10p-8a
    ReefAngel.Timer[1].SetInterval(20);  //change interval to short bursts
    ReefAngel.DelayedOn(Port5,1);    //delay 1 minute between bursts
    ReefAngel.DelayedOn(Port6,1);   //delay 1 minute between bursts
  //8a-10p normal wave settings
Re: Slow down waves at night
Posted: Tue Nov 08, 2011 8:50 am
I did not quite understand what you are trying to accomplish.
Correct me if I'm wrong.
During the day, which is from 9am to 10pm, you have a symmetric alternating cycle between 5 and 6 of 200s.
But you would like to have during the night, which is from 10pm to 9am, an asymmetric cycle, that would be 5 on for 20s, then 6 on for 20s then both off for 60s.
Is it correct?
If not, please clarify.
Posted: Tue Nov 08, 2011 9:42 am
by jsclownfish
That is close, but not quite the same. The daytime part is correct. Symmetric alternating powerheads on opposite sides of the tank for 200s.
During the night I want some water movement, but not the same level of back and forth. So I thought I would have the pumps alternate for 20s, but have a one minute delay between them.
Pump 5 on 20s
Pump 5 & 6 off 1 minute
Pump 6 on 20s
Pump 5 on 20s
Posted: Tue Nov 08, 2011 6:03 pm
Give this a try
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte wmport=Port5;
boolean wmdelay=false;
    if ((hour() >= 22) || (hour() <= 8)) //from 10p-8a
      if (wmdelay)
        ReefAngel.Timer[1].SetInterval(60);  // wm night delay
        ReefAngel.Relay.Off(Port5);
        ReefAngel.Relay.Off(Port6);
        if (wmport==Port5) wmport=Port6; else wmport=Port5;
        wmdelay=false;
        ReefAngel.Timer[1].SetInterval(20);  // short wave
        ReefAngel.Relay.On(wmport);
        wmdelay=true;
Posted: Thu Nov 10, 2011 9:11 pm
by jsclownfish
Works great! Thanks! I can't tell you how much I enjoy the flexibility of this system and the great support.
Posted: Fri Nov 11, 2011 1:53 pm
by jsclownfish
Oops, I spoke to soon. It works at 10PM to slow down the waves, but it didn't reset at 8 AM. Any ideas?
Here is my pde.
//Cloud & Lightning effects
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte wmport=Port5;
      if (wmdelay)
        ReefAngel.Timer[1].SetInterval(100);  // wm night delay 100 seconds between pulses
        wmdelay=false;
        ReefAngel.Timer[1].SetInterval(50);  // waves of 50 seconds alternating
        wmdelay=true;
  //Using Daylight ATO high signal piezo buzzer when temp exceeds 83F
if (ReefAngel.Params.Temp1>830)
  pinMode(highATOPin,OUTPUT);
  digitalWrite(highATOPin,HIGH);
  {pinMode(highATOPin,OUTPUT);
  digitalWrite(highATOPin,LOW);
    //Moonlight=byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
   ActinicPWMValue=PWMSlope(7,00,22,0,0,100,60,ActinicPWMValue);
   DaylightPWMValue=PWMSlope(7,00,22,0,0,100,60,DaylightPWMValue);
Posted: Fri Nov 11, 2011 1:55 pm
Changes at 9
Posted: Fri Nov 11, 2011 1:59 pm
by jsclownfish
right, of course. ">=8" means at 9. I left for work before I could catch the change. THANKS!
Posted: Mon Nov 14, 2011 8:57 am
by jsclownfish
So the next logical step for me on this little project would be to gradually slow the waves down and pick them up in a diurnal cycle. I worked up this idea off of Roberto's teachings to give it a try. The idea is that the code slowly increases the pause between decreasing and alternating powerhead bursts. Then the opposite will happen as we move towards morning. Do you think this will work? Thanks for the advice.
//Actinic and Daylight PMW are on the LED moonlights
byte wmport=Port5;
#include <avr/pgmspace.h>
// Labels for the web banner
prog_char id_label[] PROGMEM = "jsclownfish";
prog_char probe1_label[] PROGMEM = "Tank";
prog_char probe3_label[] PROGMEM = "Sump";
prog_char relay1_label[] PROGMEM = "Heater";
prog_char relay2_label[] PROGMEM = "Heater2";
prog_char relay3_label[] PROGMEM = "Halide";
prog_char relay4_label[] PROGMEM = "Actinic";
prog_char relay5_label[] PROGMEM = "WM1";
prog_char relay6_label[] PROGMEM = "WM2";
prog_char relay7_label[] PROGMEM = "Sump";
prog_char relay8_label[] PROGMEM = "Fan";
    if ((hour() >= 22) || (hour() <= 2)) //from 10p-2a
      if (wmdelay)
        //totals about 5 hours gradual slow totals 18000 sec or 5 hrs.
        int WMcounter=0;
        for (WMcounter = 0; WMcounter < 89; WMcounter++);  //loop from 0 to 89 (slow increase delay)
        ReefAngel.Timer[1].SetInterval(WMcounter);  // wm night delay between pulses
        wmdelay=false;
        int WMcounter2=200;
        for (WMcounter2 = 200; WMcounter2 > 111; WMcounter2--);  //loop from 200 to 111  (slow decrease in pulse time)
        ReefAngel.Timer[1].SetInterval(WMcounter2);  // waves alternating
        wmdelay=true;
    else if ((hour() >= 3) || (hour() <= 7)) //from 3a-8a
      if (wmdelay)
        //totals about 5 hours gradual increase of waves
        int WMcounter=89;
        for (WMcounter = 89; WMcounter > 0; WMcounter--);  //loop from 0 to 89 (slow decrease delay)
        wmdelay=false;
        int WMcounter2=111;
        for (WMcounter2 = 111; WMcounter2 < 200; WMcounter2++);  //loop from 200 to 111  (slow decrease in pulse time)
        wmdelay=true;
// Web Banner stuff
        ReefAngel.Timer[4].Start();
        ReefAngel.WebBanner();
Posted: Mon Nov 14, 2011 9:26 am
I don't think it will work.
The "for" statements are doing nothing for the counter that you need to use.
Let me soak the idea and think of another way.
Posted: Mon Nov 14, 2011 9:51 am
those for loops are empty loops and will just do a rapid increase or decrease with end result being the final value. you will have to do something different if you want the intervals to change with each activation of them.
i will also take a look at this problem too and see if i can come up with something in addition to roberto.
Posted: Mon Nov 14, 2011 1:01 pm
by jsclownfish
OK, thanks. I was trying to mimic the code used in this LED dimming example.
// Example 04: Fade an LED in and out like on
// a sleeping Apple computer
// Copy and paste this example into an empty Arduino sketch
#define LED   9 // the pin for the LED
int i = 0;      // We’ll use this to count up and down
void setup() {
  pinMode(LED, OUTPUT); // tell Arduino LED is an output
void loop(){
  for (i = 0; i < 255; i++) { // loop from 0 to 254 (fade in)
    analogWrite(LED, i);      // set the LED brightness
    delay(10); // Wait 10ms because analogWrite
               // is instantaneous and we would
               // not see any change
  for (i = 255; i > 0; i--) { // loop from 255 to 1 (fade out)
Posted: Tue Nov 15, 2011 9:37 am
If I understand correctly and looking at the code, the only thing you want to change is this value, correct?
If this value is 0, it would make the wm alternate on 20s cycle just like during the day.
So, at night, you want the interval to grow from 1 to 60 and back down to 1 between 10pm and 9am.
We can use the PWMSlope function, which is already created to do that if this is what you wanted. :)
Posted: Tue Nov 15, 2011 10:03 am
by jsclownfish
Well, that's close. I wasn't sure if the PWMSlope function would work on a relay. I thought it might only work on the LED ports. Basically, I tried to code something like this and add the totals to make 10 hours (5 slowing down, 5 speeding up). I thought the flow would be like this : R right side powerhead, L left side powerhead, D delay (all in seconds)
200 R
0 D
199 L
1 D
198 R
2 D
197 L
3 D
196 R
....(5 hours)
Then reverse order for 5 hours back to 200 alternating, no delay.
Jon
Posted: Tue Nov 15, 2011 10:46 am
Ah, ok.
So you are scratching the original 20s, pause, 20s and making the 20s also a variable.
Got it.
At the peak of 5 hours, you would have wm on for just 1 second and pause for 199 seconds, which at that point, the pause would start decreasing and the on time for powerhead increases, right?
Something doesn't add up though.
10hrs=36000 seconds.
Whatever I understood would create 200 steps of 200 seconds each=40000s just for sloping down and another 40000s for sloping up.
Maybe I'm missing something.
Posted: Tue Nov 15, 2011 1:11 pm
by jsclownfish
Yes, that is correct. That is why I tried to cap the cycles at 89 and 111 as it totalled 10 hours. The loop would not reach a full cycle.
Posted: Tue Nov 15, 2011 1:42 pm
Now that I understand what you were trying to accomplish, would you prefer having a full 200s to 1s ramp, even though there would be steps of 2 or 3 seconds??
Or you prefer having steps of 1 sec and cap it at 89/111??
Posted: Tue Nov 15, 2011 1:53 pm
by jsclownfish
Honestly, haven't thought it through to that detail. I suppose I'd like to limit it down to about 30 sec on and 170 off, but either way would probably work. I wanted to run it for a couple weeks to see how the tank (coral) responds.
Posted: Wed Nov 16, 2011 10:40 pm
Give this a try:
byte wmport=Port5;
byte wmpulse=0;
      wmpulse=PWMSlope(22,0,8,0,30,170,255,30);
      if (wmdelay)
        ReefAngel.Timer[1].SetInterval(200-wmpulse);  // wm night delay
        wmdelay=false;
        ReefAngel.Timer[1].SetInterval(wmpulse);  // short wave
        wmdelay=true;
Posted: Fri Nov 18, 2011 9:01 pm
Haven't come up with anything yet. Is that solution working for you?
Posted: Sat Nov 19, 2011 11:38 am
by jsclownfish
I loaded it today, I'll let you know soon. Thanks!
Posted: Sat Nov 19, 2011 10:29 pm
by jsclownfish
It's not quite there yet. I checked it at 11 pm and there was a delay between alternating power heads, but the pulse (powerhead on) was about 100sec with a >200sec delay (powerheads off). After only an hour I'd expect it to have pulses at about 180sec with a 20sec delay. The delay would increase for the first 5 hours and the pulses decrease. Then it would pick up again for the next 5 hours. Here is my full code in case I'm missing something else. As always, thanks for the help!
byte wmport=Port5;
byte wmpulse=0;
  ReefAngel.Init();  //Initialize controller and start web banner timer
  ReefAngel.Timer[4].SetInterval(180);  // set interval to 180 seconds
      if (wmdelay)
        wmdelay=false;
        wmdelay=true;
// Web Banner stuff
-Jon
Posted: Sun Nov 20, 2011 9:45 am
Let me look into it some more
Posted: Sun Nov 20, 2011 6:01 pm
Ok, after reviewing the code, I realized I was doing the opposite.
I was increasing the pulse from 30 to 170 within 255 minutes.
The delay is just the result of 200 - pulse, which mean 170 to 30 withint 255 minutes.
Then, it would stay at pulse 170 and delay 30 for around 30 minutes and finally the opposite for the next 255 minutes.
The reason of the flat 30minutes with no change is because we can only slope a max of 255 minutes.
Both ramps sum up 510minutes, but the entire night period is 9 hours = 540 minutes.
If you want to do the opposite, which is pulse of 170 to 30 within 255 minutes, I can change the logic.
Let me know which way you prefer.
Posted: Tue Nov 22, 2011 2:31 pm
by jsclownfish
So in the middle section when the slope 'down' has run it's course, does the pattern hold steady at 30(R)-170(OFF)-30(L) and then start the slope build 'up' (shorter delays & longer pulses) until morning? I think that would work fine.
Jon
Posted: Tue Nov 22, 2011 3:58 pm
Yes.
Posted: Mon Nov 28, 2011 7:25 pm
by jsclownfish
I switched the code like you recommended and I think it works now. The Custom Main with the timer (I borrowed from another pde posted) has been really helpful in trying to 'time' the steps. However, when I try to change the clock to see how it behaves once the code is loaded, it goes way off and extends the time of the first step by as much as 10000sec. If I change the clock, then load the code it seems to work fine. Do I need something to reset it if I change the clock?
Jon
#include <ReefAngel_Colors.h>
byte wmport=Port5;
byte wmpulse=0;
prog_char relay1_label[] PROGMEM = "H1";
prog_char relay2_label[] PROGMEM = "H2";
prog_char relay3_label[] PROGMEM = "MH";
prog_char relay4_label[] PROGMEM = "Act";
prog_char relay7_label[] PROGMEM = "Main";
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(0, 1, 11, 132, 11);
// Display the Tank temperature with color sensors
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,13,"TK:");
  if (ReefAngel.Params.Temp1>830) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_RED, 23, 13, 10);
  else if (ReefAngel.Params.Temp1>810) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_ORANGE, 23, 13, 10);
  else ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_BLACK, 23, 13, 10);
// Display the Room temperature
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,5,23,"RM:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, 0, 23, 23, 10);
// Display the Sump temperature
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,5,33,"SP:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, 0, 23, 33, 10);
// Display the PH with color sensors
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 64, 13,"PH:");
  if (ReefAngel.Params.PH>840 || ReefAngel.Params.PH<790) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, COLOR_RED, 82, 13, 100);
  else if (ReefAngel.Params.PH>830 || ReefAngel.Params.PH<800) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, COLOR_ORANGE, 82, 13, 100);
  else ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, 0, 82, 13, 100);
// Display the % Moonlight
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 64, 23,"MN:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), 0, 82, 23, 1);
// Display arrows for Wavemaker
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 64, 33,"WV:");
  if (bitRead(ReefAngel.Relay.RelayData,Port5)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 33,"-->"); //port 5 on
  else if (bitRead(ReefAngel.Relay.RelayData,Port6)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 33,"<--");  //port 6 on
  else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 33," O "); //port5 and port 6 off, wavemaker delay
ReefAngel.LCD.DrawOutletBox(12, 45, TempRelay);
//#ifdef RelayExp
// draw 1st expansion relay
//TempRelay = ReefAngel.Relay.RelayDataE[0];
//TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
//TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
//ReefAngel.LCD.DrawOutletBox(12, 55, TempRelay);
//#endif // RelayExp
    int t=ReefAngel.Timer[1].Trigger-now();
    if (t>=0)
      ReefAngel.LCD.Clear(255,105,33,135,43);
      ReefAngel.LCD.DrawText(0, DefaultBGColor,105,33,t);
ReefAngel.LCD.DrawGraph(1, 75);
    if ((hour() >= 22) || (hour() <= 8)) //from 10p-9a
    {  //PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM,
       // byte endPWM, byte Duration, byte oldValue)
      if (wmdelay)
        ReefAngel.Timer[1].SetInterval(wmpulse);  // WM delay function from 30-170 sec.
        wmdelay=false;
        ReefAngel.Timer[1].SetInterval(200-wmpulse);  // WM bursts timing from 170-30 sec.
        wmdelay=true;
  //other options are lowATOpin or the LED pins as ReefAngel.PWM.SetDaylight(100); else ReefAngel.PWM.SetDaylight(0);
// Web Banner stuff
Posted: Mon Nov 28, 2011 8:06 pm
On your DrawCustomMain() function, you have this:
    if (t>=0)
Change it to this:
    if (t>=0)
    if (t>=300) ReefAngel.Timer[4].ForceTrigger();
That should force the timer to reset if it is greater than 300 sec.
Let me know if this works.
Posted: Mon Nov 28, 2011 11:10 pm
by jsclownfish
Thanks. That fixed the timer after changing the clock so I could get a better look at things. However, it seems to work fine until it reaches 00:00 (midnight). At that point the wave cycle resets to 170(R)-30(OFF)-170(L), up until that point it is making a gradual increase of the delay to about 93 sec and 77 sec pulses. The build side seems to work fine.
-Jon
Posted: Tue Nov 29, 2011 9:47 am
I guess I never thought of the PWM ramp crossing over from one day to another.
Let me think about a solution.
