Code to turn on Feeding mode ?
Posted: Thu Dec 26, 2013 2:02 pm
How would I code this to turn on feeding mode at a certain time, instead of using the app or portal.
https://forum.reefangel.com/
static unsigned long feeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
if ( feeding == 0 ) {
feeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-feeding>=60) && (now()-feeding<=61)) //if between 60 and 61 seconds has past
ReefAngel.Relay.On(Feeder); //TURN FEEDER RELAY ON
ReefAngel.Relay.Off(Feeder); //TURN FEEDER RELAY OFF
} else {
if ( feeding > 0 ) {
feeding = 0;
