analog dimming of OSRAM ballast with 1-10V interface
Posted: Sun Dec 29, 2013 11:48 am
Hi,
hope you don't mind if I ask before testing, but I want to avoid to damage my RA or other hardware
I use OSRAM ballasts (QTi 1x35/49/80/220-240 DIM) that have a 1-10V interface for dimming. But if I get this right this is realized as a current sink (hope this is the right term in english
). Here the ballast produces the voltage itself and the current is controlled with a resistor. I currently do manual dimming with a 100kOhm poti. 0 Ohm gives 1% and 100kOhm 100% brightness.
When I look at the RA analog dimming, this is also named "1-10V", but here the RA produces the voltage. So I suppose this is not the same interface and connecting the pins could damage something. Am I right and if so, can I use it anyway with some modifications between?
cheers,
Christian
cheers,
Christian
