Question on portal notifications
Posted: Fri Jan 03, 2014 10:12 am
by Marvollo
I just got the wifi attachment up and running. i can see the status of my parameters in portal. I went to portal settings and wanted to test out notifications so I set up temperature and ph alerts and saved them.
I have not received any email notifications even though it should with my settings.
Do I also need to generate code to save in the internal memory for this feature to work?
Re: Question on portal notifications
Posted: Fri Jan 03, 2014 10:15 am
It only sends it once per hour.
You may need to wait until it is one hour after the last one sent.
