Jebao Connection to RA+
Posted: Fri Jan 03, 2014 10:58 am
by Leafies
I am working through connecting my new RA+ step by step here and one thing that has me puzzled is what ports I connect my Jebao controller cables to. The two ports on the relay box? or the two ports on the RA+? I've tried both and I have the code correct (I think) and they don't seem to be doing anything for me.
I have two Jebao wp-40's and a RA+ with bluetooth.
Re: Jebao Connection to RA+
Posted: Fri Jan 03, 2014 11:02 am
The ones on the head unit are ATO ports. Don't use those.
You need to use the dimming ports in the relay box.
Posted: Sat Jan 04, 2014 1:57 pm
by Leafies
I have the WP-40 pumps connected to the correct ports on the relay. I have rebooted the entire system and plugged the skimmer into the relay as a tester. The skimmer works perfectly with the relay box even with the programmed delay. I can hear the relay switching ports 5 & 6 on and off for the pumps and the display shows them cycling on and off however the pumps will not turn on and I am failing to understand what I am missing. Thanks
Posted: Sat Jan 04, 2014 3:32 pm
You don't need to use the wavemaker function. That is for non-controllable koralias. They simply turn on/off the relays.
Make sure that you checkmark DC Pump when you are generating the code in the wizard.
Posted: Sun Jan 05, 2014 1:37 pm
by Leafies
To be honest I purchased these pumps for the wavemaker function... but I guess my question is if I select DC pump as I have in the wizard and I set the port to Wavemaker will the codes conflict with each other?
Posted: Sun Jan 05, 2014 1:59 pm
The jaebo pumps with the cable dont need the wavemaker. There are plenty of wave forms that you can use. The long pulse is like the wavemaker function.
Posted: Sun Jan 05, 2014 7:15 pm
by ReEfnWrX
I have never been able to get a wave form from Long pulse... Only short pulse... and it's a hell of a wave. in my 90 gallon at 70% power, 400ms intervals with the pump 10" below water line I Get a 2" wave.
Did you mean to say Short Pulse? Or is there something I am not figuring out to get waves from long pulse, because honestly, I'd rather avoid such rapid on/off's
Posted: Mon Jan 06, 2014 6:45 pm
by Leafies
I believe that the pumps are connected properly at this point. While uploading the code via bluetooth, both pumps come on 100% power and once the code is uploaded and the RA+ is fully rebooted they both shut off. I have included my code below as I'm not sure what else to do here.
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
ReefAngel.CustomLabels[0]="ReturnPump";
ReefAngel.CustomLabels[1]="Heater";
ReefAngel.CustomLabels[2]="Skimmer";
ReefAngel.CustomLabels[3]="SumpLight";
ReefAngel.CustomLabels[4]="Jebao1";
ReefAngel.CustomLabels[5]="Jebao2";
ReefAngel.CustomLabels[6]="Actinic";
ReefAngel.CustomLabels[7]="Daylight";
ReefAngel.StandardHeater( Port2,745,760 );
ReefAngel.Relay.DelayedOn( Port3,5 );
ReefAngel.StandardLights( Port4,20,0,6,0 );
ReefAngel.StandardLights( Port7,8,0,21,0 );
ReefAngel.StandardLights( Port8,9,0,20,0 );
ReefAngel.DCPump.SetMode( ShortPulse,10,1000 );
Posted: Mon Jan 06, 2014 9:58 pm
Which channel are they connected to?
Posted: Mon Jan 06, 2014 10:15 pm
by Leafies
Success!! The problem was I had the sync/antisync settings wrong... after hours and hours of searching forums I found out that if you have two jebao's they have to be offsetting.
ReefAngel.DCPump.SetMode( LongPulse,40,10 );
ReefAngel.Portal("Leafies","key");
Posted: Tue Mar 11, 2014 8:56 pm
by wolffman64
What does the offsetting do? (sorry, real newbi)
Edit: No worries - found out in the thread "wave patterns"
