Code for only first part of the slope dimming leds
Posted: Sun Jan 05, 2014 2:34 pm
by lmolenmaker
Hi Guys,
Can someone help me to a code where I need my actinic channel ramping up from 3% to 20%, starting at 8am, ending at 9am.
Same for the ramping down , lets say start at 20% down to 3%, from 10pm to 11 pm.
All I can find is is full parabola's and slopes. I just need the ramping up parts and ramping down parts.
If you guys can help me out here, that would be great.
Thanks in advance,
Leslie
Re: Code for only first part of the slope dimming leds
Posted: Sun Jan 05, 2014 3:51 pm
That's what the slope does
Posted: Sun Jan 05, 2014 4:33 pm
by lmolenmaker
Hi Roberto,
From my understanding of the slope is that it will ramp up (in my example) to 20% and stay on 20% until 10pm and then ramp down.
That is not what I need. I would like the leds ramp up to 20% in an hour and ramp down at the end. I don't need the middle part of the slope.
The middle part will be taken care of by another rule.
Hope this is a little bit more clear.
Leslie
Posted: Sun Jan 05, 2014 5:03 pm
So do the normal slope and then add a statement after that to set those channels to 0%.
Posted: Sun Jan 05, 2014 5:35 pm
by lmolenmaker
Dear Lee,
This is way above my knowledge. But I give it a try.
Is it something like this for the ramping up part?
ReefAngel.PWM.SetActinic( PWMSlope(8,0,0,0,3,20,60,0) );
The way I read the above is at 8am it starts ramping up to 20% for 60 minutes and then it stays at 20% until 11pm, then it ramps down to 3% for 60 minutes.
I am confused.
Leslie
Posted: Sun Jan 05, 2014 5:55 pm
Yes that looks good for the slope.
Now you need a statement between 9 and 11 to set the channel to 0.
if (hour()>=9 && hour()<23) ReefAngel.PWM.SetActinic(0);
Posted: Sun Jan 05, 2014 6:18 pm
by lmolenmaker
Dear Lee or Roberto,
ah I see. So the following below is my piece of code, I verified it, which was ok. I changed the values and times a bit, but I am not sure if it is going to do what I want it to do.
all those brackets and equal signs really get me confused. Would you mind having a look at it?
What I want to accomplish is:
*8.30 am actinic ramping up to 20% for 60 minutes
* then the parabola rules take it over until 21.30
* then at 21.30 actinic ramping down to 0% for 60 minutes
Thanks in advance.
Leslie
if (( hour()>=9) && (minute()>30) && ( hour()<=21) && (minute()<30) )
ReefAngel.PWM.SetDaylight( PWMParabola(9,30,21,30,3,30,0) );
ReefAngel.PWM.SetActinic( PWMParabola(9,30,21,30,20,50,0) );
ReefAngel.PWM.SetActinic( PWMSlope(8,30,22,30,0,20,60,0) );
