RA Wizard - No Night Mode?
Posted: Sat Jan 11, 2014 6:38 am
by AnesthDoc
Newbie here.
While setting up the Reef Angel Wizard, I realized there are no settings for the night mode and that means the wave makers will be running at full speed at night.
Am I missing something?
Re: RA Wizard - No Night Mode?
Posted: Sat Jan 11, 2014 7:20 am
by ReEfnWrX
The Wizard is just a way to get you started with the basic functions. You can create custom coding if you want to run a different pattern at night.
Posted: Sat Jan 11, 2014 8:32 am
by AnesthDoc
Is there a "newbie-friendly" way to make that adjustment.
I don't know much about coding at this point.
Posted: Sat Jan 11, 2014 8:41 am
by ReEfnWrX
Can you copy and paste the code you are using. The code the Wizard generates for you at the end.
paste it inbetween [ code] paste it here [ /code] without the spaces in the brackets.
Posted: Sat Jan 11, 2014 9:15 am
by AnesthDoc
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.DelayedOn( Port2,15 );
ReefAngel.Wavemaker( Port5,120 );
ReefAngel.DCPump.SetMode( LongPulse,100,60 );
ReefAngel.DCPump.DaylightChannel = AntiSync;
ReefAngel.Portal( "AnesthDoc" );
Posted: Sat Jan 11, 2014 9:18 am
by ReEfnWrX
Are you trying to keep the longpulse mode at a lower speed or change to a constant low speed at night?
Posted: Sat Jan 11, 2014 9:38 am
by ReEfnWrX
Lets say you want to set Longpulse during the day and constant mode at night
In your void loop()
remove this line
then in the void loop() custom code area put this
if (hour()>=22 || hour()<11) { // if hour is >=10pm or hour is <11am
ReefAngel.DCPump.SetMode( Constant,30,10 ); // Set dc pump mode to Constant at 30% power
else if (hour()>=11 && hour()<22) { // if hour is >=11am and <10pm
ReefAngel.DCPump.SetMode( LongPulse,100,60 ); // Set dc pump mode to LongPulse at 100% power, 60 second duration
So this would be your new code
Posted: Sat Jan 11, 2014 10:49 am
by AnesthDoc
Awesome and thanks for making it look so easy.
Do I remove the original code or just copy and paste the new code?
Posted: Sat Jan 11, 2014 10:56 am
by ReEfnWrX
I gave you the option to edit your code or just replace it all together
Posted: Sat Jan 11, 2014 11:01 am
by AnesthDoc
What would be a good place for someone like me to learn how to code.
Thanks again for all your help and time.
Posted: Sat Jan 11, 2014 11:04 am
by ReEfnWrX
http://forum.reefangel.com/viewtopic.php?f=14&t=3353
There is a post where someone took some basic Wizard generated code and explained it bit by bit. That is a good start, after that I would say look at threads where people ask how to do code... Will take time...
Posted: Sat Jan 11, 2014 11:26 am
by AnesthDoc
Great help!
I am taking my first step today. Thanks for helping me start.
Posted: Sat Jan 11, 2014 11:31 am
by ReEfnWrX
Only returning the favor, I just started in december... I am amazed at what you can accomplish with the RA
Posted: Thu Jan 16, 2014 11:10 am
by AnesthDoc
I am looking at this post for the Wave Pattern Modes and have a question.
http://forum.reefangel.com/viewtopic.php?f=7&t=2844
I click "Select All" next to the CODE then click copy.
Where in the main code do I paste this code?
Do I need to alter anything for the code to work and what if I wanted to tweak the variables, i.e time/duration etc.
Thanks in advance!!
Posted: Fri Jan 17, 2014 6:33 am
by ReEfnWrX
Now all of those patterns have been implemented into the DCPump classes which you are currently using. So if you want to continue using the DC pump mode you do not need to copy and paste that code.
If you want to see the code used for each of those in DC pump mode. Just launch the wizard and select a different wave pattern and select your speed and duration setting if applicable then generate the code and look for the line similar to this but with the different mode.
One of the benefits to not using the DCPump class and using the custom code from that thread is you have more control over the wave pattern.. example you can set minimum speed.
Now all of those custom codes have been implemented into the libraries so you do not need to copy and paste those. You just need to call them.
ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) );
To do this you would place this code into the area inbetween
////// place your custom code below here
and remove your DCPump.Setmode code.
Also, the values after the mode ( ReefCrestMode(70,20,true)
On that page Where you see it says ReefCrest then WaveSpeed Wave Offset Pulsync on different lines those are the values you need to define in ( ) after ReefCrestMode
so Nutrient Transport would be
Reefangel.PWM.SetDaylight( NutrientTransportMode(30,80,20,true) );
Posted: Fri Jan 17, 2014 6:50 am
That code is not correct. You could do
ReefAngel.DCPump.SetMode( Constant );
ReefAngel.DCPump.Speed=LongPulseMode(100,60,false );
The problem with that is you wont get Sync/AntiSync behavior.
You could set the mode to Custom and then set each channel manually as well.
Posted: Fri Jan 17, 2014 9:41 am
by ReEfnWrX
The code I listed is based off of DC pump codes the wizard has generated, and I did not mention the other DCPump lines because eh was already using the DCPump class and they should be there.
You seem to be using a different method than what the wizard generates
Posted: Fri Jan 17, 2014 9:57 am
Maybe you meant Speed instead of Mode...speed can be set as a value from the LongPulse function but Mode would just get screwed up and keep changing modes and most would be invalid...check your output from the wizard and what you posted again...
Posted: Fri Jan 17, 2014 9:58 am
I'm sorry just reread the code...using the SetMode function...my bad. You were correct sir.
Posted: Sat Jan 18, 2014 5:37 am
by AnesthDoc
Appreciate the replies, I will be tweaking the modes today.
