Relay expansion box randomly resets
Posted: Sun Jan 12, 2014 5:03 pm
by keithb
I have an issue where the relay box that's plugged into my relay expansion. When the relay expansion is plugged into the hub it will randomly make a loud clicking noise and drop power to all ports on the attached relay box for a split second. It will do this multiple times in an hour. If I plug the relay expansion directly into the head unit, the problem goes away. Any idea what's causing this?
Re: Relay expansion box randomly resets
Posted: Sun Jan 12, 2014 10:08 pm
Would you be able to swap relay boxes around and see what happens?
Posted: Mon Jan 13, 2014 12:35 am
by keithb
Yeah, but I won't be able to do that for a couple days. With that said, I've definitely narrowed it down to only when it's plugged in to the expansion hub. It would be easier for me to eliminate that as a possible cause just because of my cable management. Can I try it with a regular USB hub?
Posted: Mon Jan 13, 2014 4:27 am
by Pny
You can not use a standard usb hub with the Reef Angel. Although using USB cables, the Reef Angel does not use the USB protocol...
Posted: Wed Jan 15, 2014 10:40 pm
by keithb
Just finished testing by swapping relay boxes and the other one exhibited the same behavior when plugged into the relay expansion while it is plugged into the expansion hub.
Posted: Thu Jan 16, 2014 10:05 am
Do you have any other expansion modules?
Does the problem happen in different ports of the HUB?
Have you tried swapping cables around too?
Posted: Thu Jan 16, 2014 10:59 am
by keithb
I haven't tried the port swap-a-roo on the hub yet. I will do that next.
I also have the PH and Salinity Expansions.
The only cable I can see as potentially being bad is the cable from the RA to the Expansion Hub. Otherwise the other cable combinations work fine as long as they're attached directly to the head unit. Please don't make me swap the others, I spent too long making the cables look good.
Posted: Tue Jan 21, 2014 7:45 pm
by keithb
It was a bad USB cable. Only did it when it was bent in a certain direction.
Posted: Wed Jan 22, 2014 12:19 am
by Jmustapha
Mine does the same thing. It will cut for a second. I've tried switching them and nothing. Keith did you jus swap out the black USB cable and it worked for you?
Posted: Sat Jan 25, 2014 9:36 am
by keithb
Yeah. Swapped out the cable with another one I had. Seems to have fixed the problem.
Posted: Mon Feb 03, 2014 1:38 pm
by Jmustapha
I tried rearranging the wires to no avail. I'm gonna try getting my hands on another cable and see if that'll help.
Posted: Sun Jun 01, 2014 10:55 am
by Jmustapha
Still having this problem. Anyone got any ideas?
Posted: Thu Jun 12, 2014 10:30 pm
by Jmustapha
Bump
Posted: Fri Jun 13, 2014 8:42 am
How often is this happening?
