New ReefAngel
Posted: Sun Feb 02, 2014 10:57 am
by Albe
Hi everyone - I have been lurking here for quite a while so I thought it is time for my first post here.
I am in South Africa - running a 75G mixed reef.
I recently got an RA+, expansion module, salinity, dimming, jebao cables and wifi. I am struggling a bit with the salinity probe giving extremely varying results, to the point where the local distributor replaced the box (not the probe). I have since figured my DIY LED unit causes some stray voltage in the tank. I have absolutely no idea how that happens as it is not touching the water but it is causing some stray voltage when it is on. When the lights are unplugged completely only then does the stray voltage disappear. Just switching off the socket does not solve it, I have remove the plug.
Anyway - I need some of the clever guys here to help me with a few things.
1: I am running the jebao cables and got some nice code here for Else mode which I do like. I have also different power modes at different times. What I need help with is to be able to change the mode from the wifi page. How can I do that?
2: Then secondly, I have built a little ghetto power sensor. I want to connect the whole RA system to my backup power, but when power goes out I want it to be sensed and switch off some of the devices. I have a 12 V power supply connected to a relay. The relay is connected to one of the ATO ports. I have tested the sensing ability, that works a charm, I just need some help on the code with that.
3: Notifications - I have set up some notifications on the portal, and linked that to a sms service. Therefore, whenever I get a portal notification, I get an sms. Ideally I want the RA to trigger the notification when the power goes out as the internet connection will only stay up for a minute or two when the power goes out. In South Africa power outages are regular occurrences so I need to get that working.
Here is my current code:
/*#include <RF.h>*/
/*#include <ORP.h>*/
/*#include <WaterLevel.h>
#include <Humidity.h>*/
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperatures
    ReefAngel.Timer[FEEDING_TIMER].SetInterval(180);  // Set Feeding time to 3 mins
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
    InternalMemory.OverheatTemp_write( 265 );
    // Feeding and Water Change mode speed
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.CustomLabels[0]="Skimmer";
    ReefAngel.CustomLabels[1]="Return";
    ReefAngel.CustomLabels[2]="Heater";
    ReefAngel.CustomLabels[3]="Fans";
    ReefAngel.CustomLabels[4]="Reactor";
    ReefAngel.CustomLabels[5]="Unused";
    ReefAngel.CustomLabels[6]="Unused";
    ReefAngel.CustomLabels[7]="Vertex";
    ReefAngel.PHMin=527;
    ReefAngel.PHMax=825;
   //* ReefAngel.SalMax=2780;*//
    ReefAngel.Relay.DelayedOn( Port1,5 );
    ReefAngel.StandardHeater( Port3,245,255 );
    ReefAngel.StandardFan( Port4,250,265 );
    ReefAngel.Relay.DelayedOn( Port5,3 );
    ReefAngel.DCPump.SetMode( Custom,70,10 );
if (hour()>=11 && hour()<21)
    ReefAngel.PWM.SetDaylight( ElseMode(30,30,true)); // Else at 30% +/- 30% on sync mode
    ReefAngel.PWM.SetActinic( ElseMode(30,30,false));
else if (hour()>=21 && hour()<23)
    ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,30,4000,true) ); // Nutrient Transport 30%minspeed - 40%maxspeed - 200ms
    ReefAngel.PWM.SetActinic( NutrientTransportMode(40,30,4000,false) );
    else if (hour()>=23 || hour()<11)
    ReefAngel.PWM.SetDaylight( ElseMode(25,15,true) ); // Else at 25% +/- 15% on sync mode
    ReefAngel.PWM.SetActinic( ElseMode(25,15,false) );
///// Sample code for notifications
 if (ReefAngel.Params.Temp[1]<750 && ReefAngel.Params.Temp[1]>0) WifiSendAlert(3,true);
  if (ReefAngel.Params.Temp[1]>760 && ReefAngel.Params.Temp[1]<1850) WifiSendAlert(3,false);
    ReefAngel.Portal( "albe" );
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 2000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,2000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
void WifiSendAlert(byte id, boolean IsAlert)
  static byte alert_status;
  if (IsAlert)
    if ((alert_status & 1<<(id-1))==0)
      alert_status|=1<<(id-1);
      Serial.print("GET /status/alert.asp?e=xxxxxxxxxx@xxxxxxxxxx&id=");
      Serial.println(alert_status,DEC);
      Serial.println("\n\n");
    if (id==0)
      alert_status=0;
      delay(900);
      alert_status&=~(1<<(id-1));
Another thing which I have noticed is that sometimes the /wifi page loads the default page, but then it seems to connect to the reefangel site to download the labels and other information. This *sometimes* takes a while so the page never gets to the point of actually displaying information. I have seen the same on a fellow reefer's RA. I think it is caused by the internet connection. Is there any way I can already specify that information in the RA's memory so that it doesn't try to get that information from the portal? Generally for american/european users it might not be an issue but down here at the bottom of Africa it can be a problem when international bandwidth is at a premium.
Re: New ReefAngel
Posted: Sun Feb 02, 2014 11:38 am
by ReEfnWrX
You can register your RA at www.reeftronics.net Anytime the site cannot communicate with your RA it will send you an email. This is a good backup/failsafe to your battery back up and RA/Portal email alerts.
Re: New ReefAngel
Posted: Sun Feb 02, 2014 11:40 am
by Albe
Thanks, I have already registered there.
I need to distinguish between a power outage and just an internet disconnect as well, thats where a notification would help a lot.
Re: New ReefAngel
Posted: Sun Feb 02, 2014 2:10 pm
Look at the function CheckPower() in my INO file. You would have to change the condition from looking at the relay expansion that I am to looking at the ATO port your using. But same concept. Same things to do before / after.
Note that the WiFiAlert() functions are not in the current production libraries.
Re: New ReefAngel
Posted: Sun Feb 02, 2014 2:23 pm
by Albe
Thanks Lee, I am trying to dissect your file at the moment.
Any suggestions on the other labels and custom modes for the jebao's in conjunction with the Else mode?
Re: New ReefAngel
Posted: Sun Feb 02, 2014 2:39 pm
by Albe
Ok I have found the code in your INO, I added the #include <WiFiAlert.h> and your wifialert files to libraries folder.
When I add the first few lines of your code I get this error:
Albe_v0_1.cpp: In function 'void CheckPower()':
Albe_v0_1:127: error: 'WiFiAlert' does not name a type
Albe_v0_1:143: error: 'powerAlert' was not declared in this scope
Albe_v0_1:155: error: 'powerAlert' was not declared in this scope
I am probably leaving something out, my programming skills are rusty to non-existent at the moment, last time I touched something like this prior to getting a RA was in 1997...
Please help?
Re: New ReefAngel
Posted: Sun Feb 02, 2014 2:43 pm
Look at Sacohen's INO for what i did with his Jaebo. As far as the /wifi code its still in development and I dont use it since it doesnt work right for me.. So no comment on that part :)
Re: New ReefAngel
Posted: Sun Feb 02, 2014 2:46 pm
by Albe
Got the wifialert working - just reimported the library, must have made a mistake the first time.
Re: New ReefAngel
Posted: Sun Feb 02, 2014 4:25 pm
Cool
