Salinity Quit On Me...
Posted: Wed Feb 05, 2014 10:23 pm
by keithb
...While I was working on the tank this evening, so I probably did something. I tried reseating everything to no avail. How can I tell if it's the probe or the module that's giving me trouble?
Re: Salinity Quit On Me...
Posted: Thu Feb 06, 2014 9:12 am
Can you check is the power supply is working?
Does it have the green led on the side lit?
Posted: Thu Feb 06, 2014 11:14 am
by keithb
LED on both the wall wart and the Module are on. Tried reseating both the probe cable and the USB cable as well as trying different ports in the expansion hub.
Posted: Thu Feb 06, 2014 11:26 am
Posted: Sat Feb 08, 2014 11:34 am
by keithb
I2CScanner ready!
starting scanning of I2C bus from 1 to 128...
addr: 1 addr: 2 addr: 3 addr: 4
addr: 5 addr: 6 addr: 7 addr: 8
addr: 9 addr: A addr: B addr: C
addr: D addr: E addr: F addr: 10
addr: 11 addr: 12 addr: 13 addr: 14
addr: 15 addr: 16 addr: 17 addr: 18
addr: 19 addr: 1A addr: 1B addr: 1C
addr: 1D addr: 1E addr: 1F addr: 20 found!
addr: 21 addr: 22 addr: 23 addr: 24
addr: 25 addr: 26 addr: 27 addr: 28
addr: 29 addr: 2A addr: 2B addr: 2C
addr: 2D addr: 2E addr: 2F addr: 30
addr: 31 addr: 32 addr: 33 addr: 34
addr: 35 addr: 36 addr: 37 addr: 38 found!
addr: 39 addr: 3A addr: 3B addr: 3C
addr: 3D addr: 3E addr: 3F addr: 40
addr: 41 addr: 42 addr: 43 addr: 44
addr: 45 addr: 46 addr: 47 addr: 48
addr: 49 addr: 4A addr: 4B addr: 4C
addr: 4D found! addr: 4E addr: 4F addr: 50 found!
addr: 51 addr: 52 addr: 53 addr: 54 found!
addr: 55 addr: 56 addr: 57 addr: 58
addr: 59 addr: 5A addr: 5B addr: 5C
addr: 5D addr: 5E addr: 5F addr: 60
addr: 61 addr: 62 addr: 63 addr: 64
addr: 65 addr: 66 addr: 67 addr: 68 found!
addr: 69 addr: 6A addr: 6B addr: 6C
addr: 6D addr: 6E addr: 6F addr: 70
addr: 71 addr: 72 addr: 73 addr: 74
addr: 75 addr: 76 addr: 77 addr: 78
addr: 79 addr: 7A addr: 7B addr: 7C
addr: 7D addr: 7E addr: 7F addr: 80
done
Posted: Sat Feb 08, 2014 11:45 am
addr: 4D found! means the controller is seeing the module.
Can you double check your probe?
If you do into calibration, does is show any numbers?
Posted: Sat Feb 08, 2014 11:54 am
by keithb
It shows a 0 and I've reseated it multiple times.
Posted: Sat Feb 08, 2014 12:45 pm
Try cleaning it. Maybe it got calcium deposit? If that doesn't work, you will need to send it back to be analysed. Pm me for a RMA number.
Sent from my Galaxy S3 using Tapatalk
