Multiple Heaters tied to individual temp probes
Posted: Sun Feb 09, 2014 8:58 pm
by aranax
Hey guys,
Can someone please help me code two separate heaters to two separate temp probes? I have a probe in my sump and one in my QT. I want T1 to monitor heater/port of my sump and T2 to monitor my QT. I'm not sure if the "standard heater" function would work for the QT since I don't see how it would know what probe to monitor (assume it looks at T1).
Here's what I have so far:
(portion in void setup)
(portion in loop)
//Temp2 Heater Overheat
if (ReefAngel.Params.Temp[T2_PROBE]>80)
ReefAngel.Relay.Off(QTHeater);
I added this to the loop portion but it will just shutoff the the QTHeater port if T2 goes over 80 (I think). It doesn't really control the QT heater the way I'd want similar to "ReefAngel.StandardHeater( (Heater),751,780 );"
Any thoughts? Your help is appreciated. Thanks.
Jeremiah
Re: Multiple Heaters tied to individual temp probes
Posted: Mon Feb 10, 2014 10:16 am
Use this:
if (ReefAngel.Params.Temp[T2_PROBE]>800) ReefAngel.Relay.Off(QTHeater);
if (ReefAngel.Params.Temp[T2_PROBE]<790) ReefAngel.Relay.On(QTHeater);
Posted: Mon Feb 10, 2014 3:09 pm
i would also suggest getting rid of these two lines because they will override the temp probe that is used for the standard heater function. it goes by the last one that is set.
