WIFI set up issue
Posted: Mon Feb 10, 2014 6:36 am
I have wifi set up for a month or so and it worked well. Then i had to reset my router and it stopped working. I tried to use the wifi set up utility but if shows all false information and an incorrect ip address. I have been trying to research this all morning but I am overwhelmed, I am new to all of this. I don't know if a firmware update went through at some point. I reset it back to factory several times as well.
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port /dev/tty.usbserial-AH01Q8U5
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to /dev/tty.usbserial-AH01Q8U5
< CMD
> reboot
< reboot
Wifi Attachment Connected to /dev/tty.usbserial-AH01Q8U5
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 86328 3 wifly-GSX-400
< 4 74920 3 web_app-GSX-106
< 7 46632 3 wps_app-GSX-131
< 9 66240 3 eap_app-GSX-101
< 11 37282 0 web_config.html
< 21 512 0 link.html
< 24 -1 10 config
< 25 -1 10 user
< 168 Free, Boot=2, Backup=2
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> save
< save
< Storing in config
< <4.00>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s newjerolly
< set w s newjerolly
< AOK
< <4.00>
> set w p changedforprivacy
< set w p changedforprivacy
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
< Disconn from newjerolly,AUTH-ERR
< Auto-Assoc newjerolly chan=4 mode=MIXED SCAN OK
< Joining newjerolly now..
> show n
< show n
< SSid=newjerolly
< Chan=4
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
Found router N300 Wireless Router
Port 2000 is now being forwarded to 1.2.3.4
< CMD
> ftp u
< ftp u
< <4.00>
< FTP connecting to 198.175.253.161
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <4.00>
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 -1 10 config
< 25 -1 10 user
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> save
< save
< Storing in config
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s newjerolly
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=newjerolly
< Chan=4
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
< Set Factory Defaults
> reboot
< <4.00>
< reboot
Factory Settings Restored
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 -1 10 config
< 25 -1 10 user
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> save
< save
< Storing in config
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s newjerolly
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=newjerolly
< Chan=4
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 -1 10 config
< 25 -1 10 user
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> save
< save
< Storing in config
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s newjerolly
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=newjerolly
< Chan=4
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <4.00>
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <4.00>
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 -1 10 config
< 25 -1 10 user
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> save
< save
< Storing in config
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s newjerolly
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=newjerolly
< Chan=4
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.00>
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 -1 10 config
< 25 -1 10 user
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> save
< save
< Storing in config
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s newjerolly
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=newjerolly
< Chan=4
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
