Screen stays backlit but is only black
Posted: Tue Feb 11, 2014 3:47 pm
by Mhumbach
Hello, I am new here and have been loving my reef angel. Recently the screen blacks out but stays backlit, I can still control it from my phone and when I reboot the controller the screen turns back on. This is my code I believe.
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.DelayedOn( Port1,1 );
    ReefAngel.StandardHeater( Port6,778,781 );
    ReefAngel.Relay.DelayedOn( Port7,1 );
    ReefAngel.SingleATO(true,Port8,300,0);
    if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port8);
    ReefAngel.Portal( "Mhumbach" );
Re: Screen stays backlit but is only black
Posted: Tue Feb 11, 2014 4:09 pm
What happens when you move the joystick?
Posted: Tue Feb 11, 2014 4:18 pm
by Mhumbach
It stays black but the back light turns on. Im close to using up all of my memory the controller could that be triggering it?
Posted: Tue Feb 11, 2014 6:56 pm
Humm. Looks like you got a bad screen then.
PM me for RMA.
