ATO setup
Posted: Tue Feb 18, 2014 8:21 am
I am a noob at this so please help me set this up properly
I would like to set the ATO up with one float switch in the sump and the other in the reservoir so the pump will not run dry when level gets to low in reservoir. I don't have room for a large reservoir and don't want the pump to burn up. How can I accomplish this. Also I would like an alert sent if the reservoir runs low. I guess it would run like a JBJ ATO. I saw a previous post about this subject matter but was not sure what needs to be inserted in the code or where. also if anything should be altered in the existing code
thanks
thanks
