Lights stay on!
Posted: Thu Feb 20, 2014 9:44 am
by fbret
Hi, bear with me - I've only been using RA for 24 hours ( but I am a coder :-)).
I used the wizard to generate the following code:
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port2Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
InternalMemory.ActinicOffset_write(30);
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port1,771,781 );
//ReefAngel.StandardFan( Port5,771,781 );
ReefAngel.PWM.SetDaylight( PWMSlope(10,0,16,0,0,100,30,15) );
ReefAngel.PWM.SetActinic( PWMSlope(9,30,17,0,0,100,30,15) );
//deal with hood fan
if (ReefAngel.Params.Temp[T1_PROBE] >= 950) ReefAngel.Relay.On(Port5); // If sensor 1 temperature >= HighTemp - turn on fan
if (ReefAngel.Params.Temp[T1_PROBE] <= 785) ReefAngel.Relay.Off(Port5); // If sensor 1 temperature <= LowTemp - turn off fan
The issue is that at 8am, the white and actinic pwm channels are still @ 15% and I suspect the tank spent the night @ 15% :-(
What am I doing wrong?
-Fred
Re: Lights stay on!
Posted: Thu Feb 20, 2014 9:49 am
The last parameter is the % that it will output when not in your light cycle.
Change that to a zero.
Re: Lights stay on!
Posted: Thu Feb 20, 2014 9:56 am
by fbret
omg... i'm such a tool!
Thanks a million!
-Fred
Re: Lights stay on!
Posted: Thu Feb 20, 2014 12:23 pm
by ReEfnWrX
Doesn't setting that to 0 disable the lights on feature?
Re: Lights stay on!
Posted: Thu Feb 20, 2014 12:28 pm
nope. the lights on actually overrides the channels no matter what.
Re: Lights stay on!
Posted: Thu Feb 20, 2014 1:55 pm
by ReEfnWrX
What Dimming % does lights on override with? Is this an adjustable value?
Re: Lights stay on!
Posted: Thu Feb 20, 2014 5:38 pm
It uses the LED PWM Daylight and Actinic values stored in the internal memory.
You can change them with the standard menu or with the android app.
