Wondering if anyone could help me out with the most efficient way to do what I'm wanting.
Trying to take a single bit that I'm using to hold bitbang values and convert to two char arrays. I'm doing it now with String methods but I want to avoid String because of memory requirements.
Here's an example of what I'm trying to go from and get to:
Start with bit value = B01101101
Get to:
"on 1,3,4,6,7"
"off 2,5,8"
Bitmath values to char array
Re: Bitmath values to char array
I'm sure there are other ways, but that's what I came up with:
char on[20];
char off[20];
byte value=B01101101;
byte index_on=0;
byte index_off=0;
Serial.begin(57600);
on[index_on++]='o';
on[index_on++]='n';
on[index_on++]=' ';
off[index_off++]='o';
off[index_off++]='f';
off[index_off++]=' ';
for (int a=0;a<8;a++)
if (value&1)
on[index_on++]='1'+a;
on[index_on++]=',';
Serial.println("on");
off[index_off++]='1'+a;
off[index_off++]=',';
Serial.println("off");
value=value>>1;
// make sure we terminate the array with 0 to indicate end of array
on[index_on-1]=0;
off[index_off-1]=0;
Serial.println(on);
Serial.println(off);
KRavEN
Great, thanks Roberto.
I had come up with something similar using sprintf to add each value to the 2 buffers but I'm betting yours will use less memory.
I'll do some testing to see what uses the least sram.
