Internal memory ATO using Multi-Channel Water Level
Posted: Wed Mar 05, 2014 2:33 am
by smellsfishy
Hey all, I've got a RA+ with the Mult-Channel Water level expansion. I'm trying to switch everything over to internal memory but running into a problem where it seems that, by default, the RA Wizard assumes that channel 0 is the one to watch for the water level. The problem is that it should be looking at channel 1. There's nothing in the .ino that I seem to be able to change, and I looked at the ATO section in the portal to see if I could specify it there but no go. Is this possible to do in memory?
Re: Internal memory ATO using Multi-Channel Water Level
Posted: Wed Mar 05, 2014 2:50 am
by smellsfishy
uhoh, I hope its not due to github issue 138? how far away is this feature from being implemented?
Posted: Wed Mar 05, 2014 8:58 am
Correct.
We don't have it implemented yet.
It will be in the next release though.
