LIghting no dimming.
Posted: Sun Mar 09, 2014 8:53 pm
my leds are dimming, I am loading the code to internal memory rather written in the code. I wanted the ability to change it on the fly if needed. I did it this way before on my old tank.
Now it isn't dimming. I did set the std light on and off times to what I wanted. not doing it. What am I doing wrong.
here is the code
here is the code
ReefAngel.Relay.On( Port4 );
ReefAngel.WavemakerRandom1(Port5,10,30); // Turn Port5 on/off random cycles that lasts from 15 to 60 secs
ReefAngel.MoonLights( Port7 );
ReefAngel.StandardATO( Box1_Port2 );
ReefAngel.CO2Control( Box1_Port3 );
ReefAngel.PHControl( Box1_Port4 );
ReefAngel.PWM.Channel0PWMSlope();
ReefAngel.Portal( "ademster" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,49,68, "SAL:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,73,68, 10 );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,82, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,82, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
