PH calibration sudden shift, broken?
Posted: Sun Mar 16, 2014 11:50 pm
I have been running reef angel for couple months, and having a kind of stable PH, 8.3 before light off and 8.0 before light on.
But this morning the ph reads 8.5, unusually high. My first suspect is the sensor error. So I tested the 7.0 calibration solution, read 7.8. Then I recalibrated it and it reads 8.1, kind of normal.
But then tonight, the reading jumps up to 10.0! 7.0 calibration solution read 8.5. I can surely calibrate it again, but is that normal that this happen?
I have another ph sensor, tried it without calibrate again, reading is similar (+0.5). That is the same difference when using the same calibration numbers. So the sensor should not be the cause of this big change.
Tried to unplugged everything else, not helping. Measure the voltage of tank water, get only 2v, not too big a deal.
Is it normal that the calibration values changed so much in half a day? Or doea this mean something is wrong? If yes, what went wrong? Then main unit?
