glitch in slow down waves at night
Posted: Sun Nov 20, 2011 9:26 pm
I am trying to mimic jsclownfish's slowing down of the wave maker at night, but after initial success, the slow down is happening outside of what I thought was coded to make it slow down from 9 pm to 8 am...It is supposed to have random master/slave wavemaker function from 8 am to 9 pm, then from 9 pm to 8 am, I am trying to have it go 25 seconds pump 1, then both off for 60 secs, then 25 seconds on for pump 2, then both off for 60 seconds, etc. Right now, it is doing the slow down outside the 9 pm to 8 am...what do I have wrong here? Thanks
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte wmport=Port5;
boolean wmdelay=false;
ReefAngel.FeedingModePorts = B00011000;
ReefAngel.WaterChangePorts = B00011000;
ReefAngel.OverheatShutoffPorts = B11000110;
ReefAngel.LightsOnPorts = B10000110;
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(30,45));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port5);
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.StandardFan(Port4);
//ReefAngel.Wavemaker1(Port5);
//ReefAngel.Wavemaker2(Port6);
ReefAngel.MHLights(Port8);
if ((hour() >= 21) || (hour() <= 8)) //from 9p-8a
if (wmdelay)
ReefAngel.Timer[1].SetInterval(60); // wm night delay
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
if (wmport==Port5) wmport=Port6; else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(25); // short wave
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-9p normal wave settings
