Q's about programming 3 dc pumps
Posted: Fri Apr 18, 2014 6:25 am
I have 3 dc pumps on my system controlled by the day, Actinic, low ato ports.
I want to start using the the SineMode but I have a few questions. There are four values you must enter min speed, max speed, duration and sync/antisync.
- How would the pumps behave if I use a different value for duration with antisync? or do I have to use the same duration when using sync/antisync?
-Do I always need to use a sync or antisync? Can I make a pump independent from the other two (in my case the low ato port)?
