Heaters
Posted: Thu May 01, 2014 6:20 am
I have two 300 watt heaters. My current code has them coming on at the same time.
I want the first heater (port 4) to come on as soon as the temp drops below 77. I want the second heater (port5) to only come on if, the temp has not reached 78.5 degrees within 30 mins of the first heater coming on.
Thank you
Is this possible with using memory. Currently I simply upload the code. I don't use memory yet
Thank you
