ato CODE not working
Posted: Sat May 10, 2014 8:28 pm
by ecam
Im trying to get this code to work. My pump is on ATO low and the float switch for the ATO tank is on high. The portal shows the proper status of switches. But the relay doesnt switch to on. What is happening?
          ReefAngel.SingleATO( false,Port6,60,0 );                            //Port 6 Auto top off
            if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Override(Port6,0);
        byte myRFMode=0;
        byte myRFDuration=0;
        byte myRFSpeed=0;
        // Ports toggled
      ReefAngel.WaterChangePorts = Port1 |Port3 | Port7| Port8| Box1_Port1| Box1_Port3| Box1_Port4| Box1_Port5; // Turn off Return, UV, Skimmer, Heater, Sump Equipment, ATO
      ReefAngel.FeedingModePorts = Port3 | Port8; // Turn off Return and Skimmer
      ReefAngel.LightsOnPorts = Port2|Box1_Port6; //Turn on ATI lights, Fan and Fuge Light
      ReefAngel.OverheatShutoffPorts = Port1 |Port3 | Port7| Port8| Box1_Port1| Box1_Port3| Box1_Port4| Box1_Port5; // ATI Lights and Heaters
                InternalMemory.OverheatTemp_write( 825 );   // Set the Overheat temperature setting
           //Box1
           ReefAngel.StandardHeater(Port1,778,790 );                        // Port1 Heater
           ReefAngel.StandardLights( Port2,23,0,9,0 );                      // Fuge Light
           ReefAngel.Relay.On(Port3);                                       //  Port3 Return Pump -- Always on
           ReefAngel.Relay.Off(Port4);                                      //  Port4 RODI
           ReefAngel.Relay.Off(Port5);                                      //  Port5 Saltwater Change
           ReefAngel.Relay.On (Port7);                                      //  Port7 Frag Tank -- Always on
           ReefAngel.Relay.DelayedOn( Port8,5 );                            //  Port8 Skimmer -- 5 min delay start
          //box 2 (Box1_Portxx)
          ReefAngel.StandardHeater( Box1_Port1,778,790 );                         //  9 Box1_Port1 Heater
          ReefAngel.Relay.Off(Box1_Port2);                                        //  10 Box1_Port2 Acropower Dosing ...
          ReefAngel.Relay.Off( Box1_Port3);                                      //  11 Box1_Port3 UV - Only turn on UV Sterilizer between 11pm and 4am
                  if ( (hour() >= 4) && (hour() < 23) )
                      ReefAngel.Relay.Off(Box1_Port3);
                      else ReefAngel.Relay.On(Box1_Port3);
          ReefAngel.Relay.On( Box1_Port4);                                      //  12 Box1_Port4 Sump Equipment-- Always on
          ReefAngel.Relay.Off(Box1_Port5);                                       //  13 Box1_Port5 JBJ Auto top off
          ReefAngel.Relay.On(Box1_Port6);                                         //  14 Box1_Port6 Cabinet Light
          ReefAngel.Relay.Off( Box1_Port7);                                       // 15 Box1_Port7 ALK Doser
          ReefAngel.Relay.Off( Box1_Port8);                                       // 16 Box1_Port8 Calc Doser
                          // Old Code
                              //moonlight dimming
                                     //    if (hour()>=6 && hour()<10) ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) ); // Moonlight Between 5-10am turn the relay on
                                     //    if (hour()>=20 && hour()<=23) ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) ); // From 8pm-Midnight turn the relay on
                                     //    else ReefAngel.PWM.SetDaylight(0);
                                     //  ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge opposite of Actinic
                                     //  ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off       Port #11 Moonlight
                                        //if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
                                        //if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay
                                     //    ReefAngel.PWM.SetDaylight( PWMSlope(20,0,23,0,100,0,180,100) );
                                     //   ReefAngel.PWM.SetDaylight( PWMSlope(6,0,10,0,9,100,240,9) );
                                     //ReefAngel.Relay.off(Box1_Port3);
                                     //  if (hour()>=10 || hour()<20) ReefAngel.PWM.SetDaylight(0);
                                     //    ReefAngel.PWM.SetDaylight( MoonPhase()+10 );
                                    // ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
                                    //ReefAngel.PWM.SetDaylight(PWMSlope(6,0,23,0,0,100,240,0));
                                    //if (hour()>=5 && hour()<20) ReefAngel.PWM.SetDaylight(0);
                                    //ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) );
                                    //ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) );
          if (hour()>=6 && hour()<11)
            myRFSetMode(ReefCrest,85,10);
          else if (hour()>=11 && hour()<13)
          else if (hour()>=13 && hour()<16)
            myRFSetMode(Smart_NTM,85,50);
          else if (hour()>=16 && hour()<19)
            myRFSetMode(ReefCrest,65,10);
            myRFSetMode(Lagoon,40,10);
        // Hardcode PH calibrations
         //ReefAngel.PHMin=544; // PH7.0
         //ReefAngel.PHMax=830; // PH10.0
         RunDosingPumps();
         LogDosingPumps();
        ReefAngel.Portal( "ecam" );
        // Parameters
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
              strcat(text,"  ");
              ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
              ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,text);
         // Main Relay Box
        // Date and Time
    // Define Your dosing pumps
    #define numDPumps 3
    byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8,Box1_Port2};
    int DPVolume[numDPumps]={ 17, 17, 7} ; // 1ml for each alk and calcium - total volume for the day
    int DPRepeat[numDPumps]={ 360, 360, 360 } ; // Repeat every 4 hrs 6x a day --- in mins
    // Define Calibration here
    int CalTime[numDPumps]={ 600, 600, 600 }; // 10 minutes / 10 minutes
    int CalVol[numDPumps]={ 350, 300,384 }; // 350ml / 300ml... .58 / .5/.64
    // Function: RunDosingPumps()
    void RunDosingPumps() {
      float rate;
      int calcTime[numDPumps];
      for (int i=0;i < numDPumps; i++) {
        rate=(float)CalVol[i]/CalTime[i];
        calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
        // Run the pumps
        ReefAngel.DosingPumpRepeat(pumpRelays[i], i*5, DPRepeat[i], calcTime[i]); // Offset between each pump is 5 minutes
      // Display Time calculated in portal
      ReefAngel.CustomVar[0]=calcTime[0];
      ReefAngel.CustomVar[1]=calcTime[1];
      ReefAngel.CustomVar[2]=calcTime[2];
    // Function: LogDosingPumps()
    void LogDosingPumps() {
      static time_t pumpTimer[numDPumps];
      static boolean pumpStatus[numDPumps];
      float rate;
      for (int i=0;i< numDPumps;i++) {
        if (ReefAngel.Relay.Status(pumpRelays[i])) {
          if (!pumpStatus[i]) {
            pumpStatus[i]=true;
        } else {
          if (pumpStatus[i]) {
            pumpStatus[i]=false;
            // Report How much volume has been dosed per day.
            // Could make this in minutes... excercise for the reader..
            ReefAngel.CustomVar[3]=pumpTimer[0]*rate;
            ReefAngel.CustomVar[4]=pumpTimer[1]*rate;
            ReefAngel.CustomVar[5]=pumpTimer[2]*rate;
        // Clear timer at end of day
        if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
        void myRFSetMode(byte m, byte s, byte d)
          if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
            myRFMode=m;
            myRFSpeed=s;
            myRFDuration=d;
            ReefAngel.RF.SetMode(m,s,d);
Re: ato CODE not working
Posted: Mon May 12, 2014 3:02 am
by ecam
Anyone. Im going on vacation today and really need my ATO working again
thanks
