Page 1 of 2
Stuggling with the LDD Drivers
Posted: Sun May 11, 2014 10:37 am
by newtoke
I just can't get them to work. Only one driver, will turn on the lights when I unplug them from the PWM connections on the relay box. How can I test to see if the LDD drivers are the issue (I do get 48 volts from it). Or if the signal is really analog out of the relay box.
Re: Stuggling with the LDD Drivers
Posted: Sun May 11, 2014 11:18 am
Not sure where you got your information, but LDD drivers are a little different than other drivers.
Check the datasheet:
http://www.meanwell.com/search/LDD-H/LDD-H-spec.pdf
They don't work with analog signals. They work with 0-5V PWM dimming.
The relay boxes output 0-10V signals. According to the datasheet, the max voltage is 6V. So, I'm not sure if the input dimming channel of your drivers got burned out or not.
Posted: Sun May 11, 2014 12:01 pm
by Sacohen
How new is your dimming module?
The newer models have jumpers in them that you can change each channel from analog to PWM to from 0-10 to 0-5v.
Although Roberto is correct you may have fried the input dimming channel of your drivers.
Try feeding a 0-5v PWM signal into it (if you have that option) and see what happens.
Posted: Sun May 11, 2014 12:50 pm
by newtoke
rimai wrote:Not sure where you got your information, but LDD drivers are a little different than other drivers.
*** URL Removed ***
I thought the relay box either outputted a PWM or Dimmer signal and I thought I bought the one with the pwm signal. (There isn't a sticker saying dimmer on the bottom). Are you saying the PWM signal out of the relay box is a 10 volt signal and not 5?
Posted: Sun May 11, 2014 12:53 pm
by newtoke
Sacohen wrote:How new is your dimming module?
Feed a 5v PWM signal? How? Where can I buy a 5 volt PWM feeder/ generator? I looked all over the internet for one and couldn't anything except for Ebay, but none of them guaranteed a 5 volt signal
Posted: Sun May 11, 2014 12:56 pm
by Sacohen
I thought you had the dimming module and weren't using the dimming ports on the relay. Yes the signal out if the relay box us 0-10v regardless of if you got the PWM or analog.
I think there is a sticker inside if I remember correctly.
Posted: Sun May 11, 2014 1:07 pm
by Sacohen
If your relay is PWM, but 0*10v you can code it to not go about 50%.
Posted: Sun May 11, 2014 1:31 pm
by newtoke
How do you code it to go 50%? And I assume you mean voltage 50% and not PWM signal 50%. Roberto is this true? If so, cool. If not, I'd rather not buy a PWM dimming module, so is it possible to build and interface/ converter?
Posted: Sun May 11, 2014 1:49 pm
by Sacohen
The PWM control signal going from the RA dimming ports to PWM in on the LDD would be 50% of the full 10v (or 5v).
Here is code for a PWM slope going from 0-50% for the daylight and actinic channels.
Times are 9am to 8pm.
    ReefAngel.PWM.SetDaylight( PWMSlope(9,0,20,0,0,50,60,0) );
    ReefAngel.PWM.SetActinic( PWMSlope(9,0,20,0,0,50,60,0) );
Posted: Sun May 11, 2014 1:57 pm
by newtoke
Sacohen wrote:The PWM control signal going from the RA dimming ports to PWM in on the LDD would be 50% of the full 10v (or 5v).
I respect your thoughts on this Steve, but as I understand what PWM is and as referenced in the following post from Roberto...
http://forum.reefangel.com/viewtopic.php?f=2&t=2980
I don't think this is correct. A PWM determines the value between the width of each pulse, it still pulses at 10 volts right?
Posted: Sun May 11, 2014 2:02 pm
newtoke wrote: I respect your thoughts on this Steve, but as I understand what PWM is and as referenced in the following post from Roberto...
Correct.
PWM will output a 0-10V PWM signal and will change the width of the pulse.
The new dimming expansion modules can outpout 0-5V PWM signals.
Posted: Sun May 11, 2014 2:12 pm
by newtoke
Correct.
Thanks Roberto... So there is no way to get the PWM signal out of the relay box to be 5 vdc?
Posted: Sun May 11, 2014 2:17 pm
Technically there is, but it will require you to open the box and solder some jumper bridges with wires to short out the gain of the op amp that boosts the signal.
Another way is to use your ATO port. They output 0-5V PWM.
Something like this:
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,2.55*80); // set Low ATO port to 80%
Posted: Sun May 11, 2014 2:44 pm
by Sacohen
Sorry you are correct. I was thinking backwards. My brain is a little foggy right now, I've been up all night the past 2 nights working on a freelance video editing job.
Posted: Sun May 11, 2014 3:39 pm
by newtoke
rimai wrote:Technically there is, but it will require you to open the box and solder some jumper bridges with wires to short out the gain of the op amp that boosts the signal.
When I set the pin mode, do I just set it in Setup and the analogWrite in the loop? Also I assume the RA libraries won't freak out over the ATO been used as a output instead of input correct?
Posted: Sun May 11, 2014 5:15 pm
No, you need to have it on loop too.
People have used this for Jebao pumps, but nobody has never tested with LEDs.
Posted: Sun May 11, 2014 6:12 pm
by newtoke
Is it true that only one ATO port can send out PWM?
Also what configuration have folks had success with?
Posted: Mon May 12, 2014 8:04 am
On the standard RA, only one, but on the RA+, you can use both.
Posted: Mon May 12, 2014 9:54 am
by newtoke
Sigh... it didn't seem to work. I put those two lines you mentioned before the "interface" method. This is what I did:
//ATO PWM output
  pinMode(lowATOPin, OUTPUT);
  pinMode(highATOPin, OUTPUT);
  analogWrite(lowATOPin, ReefAngel.PWM.GetActinicValue() * 2.55);
  analogWrite(highATOPin, ReefAngel.PWM.GetDaylightValue() * 2.55);
  ReefAngel.Portal();
I am ordering new drivers in case I fried them. Any other ideas? I'd really love to find a testing device that can generate a PWM signal and a device that can test a PWM signal, but I have yet to find any.
Posted: Mon May 12, 2014 10:03 am
by Sacohen
What size LDD do you need.
I think I have 2 1000mA that I'm not using.
Posted: Mon May 12, 2014 10:16 am
by newtoke
I already ordered two 1000ma Steve... Thanks for the offer. I ordered the PWM Expansion Module, because it appears that is the only way people are having success... I would though hope that Roberto will add the ability to modify the voltage out of the relay pack PWM outputs in the future.
Posted: Mon May 12, 2014 10:23 am
by Sacohen
No Problem. Good luck with them.
I have 4 that I need to get motivated to set up.
Posted: Mon May 12, 2014 11:49 am
by newtoke
newtoke wrote:Sigh... it didn't seem to work. I put those two lines you mentioned before the "interface" method. This is what I did:
//ATO PWM output
  ReefAngel.Portal();
Roberto any thoughts on this code?
Posted: Mon May 12, 2014 11:54 am
Code looks fine.
Sent from my SM-G900P using Tapatalk
Posted: Mon May 12, 2014 1:16 pm
by newtoke
Doesn't work... Only thing that happens is that the lights go out. Hopefully the dimmer module I just purchased will solve this?
Posted: Mon May 12, 2014 1:30 pm
by blert
newtoke wrote:Sigh... it didn't seem to work. ...
The LDD drivers and the controlling device MUST share a common ground. You can't just send them a signal and have them work, they need to be properly hooked up electrically.
Posted: Mon May 12, 2014 1:45 pm
by newtoke
I know the ground from the RA ATO port was connected to the -Vout on the power supply. I was trying to use Roberto's suggestion of having using the ATO as a PWM 5vdc signal using the code shown in earlier in this thread, but the lights would just stay dark.
Posted: Mon May 12, 2014 2:07 pm
Do you get any voltage when you measure the ago ports?
Posted: Fri May 23, 2014 1:00 pm
by newtoke
I went ahead and purchased the Dimmer module. I opened it up and put in the 5 vdc jumpers. I wired ther LDD white wire to the dimmer and the negative or ground of the DImmer module to the negative VOut on the power supply and the lights don't turn on at all.
If I disconnect the white wire from the dimmer module then I get 100% full on from my lights
Posted: Fri May 23, 2014 1:16 pm
Did you change your code to use the dimming expansion module?
Can we see it?
