Sketch too big - please help
Posted: Tue May 13, 2014 12:31 pm
by Poiromaniax
Hi guys,
I have just compiled this using the Wizard. I am getting a "too big" error. I need the features to be configured as Ive set them, but if it helps, I need next to nothing on the controller screen - PH and temp only (would be nice if the text was large but if it keeps the sketch small then i dont mind regular size text)
    ReefAngel.FeedingModePorts = Port5Bit;
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.DayLights( Port1 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.Wavemaker1( Port5 );
    ReefAngel.Portal( "poiromaniax" );
    int x,y;
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
Also, how do I set my vortech to go into feed mode when I press feed mode button? (Port 6 is my vortech)
Re: Sketch too big - please help
Posted: Tue May 13, 2014 11:00 pm
by Poiromaniax
Ok, What ive done is removed this line:
What negative effects will this have? I use dyndns for my RA and have the dyndns address defined in portal settings
it drops my sketch down to 28,000kb instead of 32,800kb
Posted: Wed May 14, 2014 5:26 am
Downgrade your libraries or upgrade your board...removing the portal line will disable the wifi
Posted: Wed May 14, 2014 5:39 am
by Poiromaniax
Even if I use dyndns directly? (with port forwarding setup correctly)
What ive noticed is that after an hour or so of using dydnds, the portal automatically changes from xxxxxx.dynds.org to my external IP address - it sometimes gets stuck like that and I have to input the dyndns address again.
Im assuming its because of this "send to portal" function? so surely if I remove the function and just stick to dyndns, it will still work?
Posted: Wed May 14, 2014 5:46 am
by binder
the portal updates its IP address for your controller every time you send data to it. so if your IP address is different than what it has listed, the portal will update. this way the IP address is always updated and accurate. it's something that roberto added.
Posted: Wed May 14, 2014 6:26 am
by Poiromaniax
Yeah I get that. But can't I just use dyndns instead of the "send to portal" function? It makes such a difference size wise
Posted: Wed May 14, 2014 9:10 am
Having that line is what enables the wifi code. It doesnt just send to the portal...thats not whats taking up extra code. My earlier recommendation stands...downgrade to the libraries you were using before.
Posted: Wed May 14, 2014 9:19 am
by Poiromaniax
Ok thanks. I was previously using 1.0.9 and even with those it's too big. Will try 1.0.8 else 1.0.7
Posted: Wed May 14, 2014 9:23 am
by Poiromaniax
Do I have to rerun the wizard with those libraries or can I just paste the code?
Posted: Wed May 14, 2014 11:14 am
Paste the code. You may have to remove the include for DCPump.h
Posted: Wed May 14, 2014 12:42 pm
by Poiromaniax
I had to go back to 1.0.7 before it worked.
I'm having a weird vortech issue though. Will start a new thread
