Kessil A360 Color Spectrum Question
Posted: Wed May 14, 2014 6:23 am
by Msoar16
Well my Kessil A360WE will be here Friday and I want to be able to come up with a code that allows me to adjust the color spectrum from the controller so I can visually see the color and corresponding dimmer % so I can chose the proper value for my ramp times. Any help would be greatly appreciated!!
Re: Kessil A360 Color Spectrum Question
Posted: Wed May 14, 2014 8:38 am
Do you have the wifi attachment?
Posted: Wed May 14, 2014 9:01 am
by Msoar16
No, it's on my list but probably still a month away from purchasing
Posted: Wed May 14, 2014 10:04 am
It's much easier with the WiFi... I think the best route is for you to use the preloaded code.
Sent from my SM-G900P using Tapatalk
Posted: Wed May 14, 2014 11:52 am
by Msoar16
By that do you mean using the wizard to randomly pick values until I find one I like?
Posted: Wed May 14, 2014 2:12 pm
No, restore to the preloaded code.
It will let you change the max % with your joystick.
Posted: Sat Jun 07, 2014 2:49 pm
by Msoar16
Problem I have is that I can't go below 11% in spectrum without the light turning off. if I unplug my cord I can get much more blue that running though the controller
Posted: Sat Jun 07, 2014 3:31 pm
Once you know the % you want you can go back to your other code and use the new % to update that code.
Posted: Sat Jun 07, 2014 6:53 pm
by Msoar16
That isn't the problem, the problem is that any time the color intensity is set below 11% the light just turns off. I knew that was an issue with intensity but haven't heard of problems dropping color all the way down to 1%
Posted: Tue Aug 26, 2014 11:22 am
by ganjero
rimai wrote:It's much easier with the WiFi... I think the best route is for you to use the preloaded code.
How do you do this with the wifi attachment?
Posted: Tue Aug 26, 2014 3:12 pm
Use the smartphone app to override the dimming channels
