Single ATO
Posted: Thu May 22, 2014 12:47 pm
by Christo
Hi Guys
If I want to use the SingleATO for the following!
The low-switch controls the sump level and the high-switch to act as a failsafe if the low-switch should get stuck at any time
Re: Single ATO
Posted: Thu May 22, 2014 1:11 pm
Try this:
ReefAngel.SingleATO(true,Port1,60,0);
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1);
Re: Single ATO
Posted: Fri May 23, 2014 12:03 am
by Christo
Thanx Roberto!
Re: Single ATO
Posted: Tue Jun 03, 2014 7:24 am
by Christo
Hi Guys! Still Strugling here!
Here is a PIC of how my floats are installed
So I want the lower one (ATOLow) to Control the level and the higher one (ATOHigh) for fail safe if something should happen to the Low switch
Re: Single ATO
Posted: Tue Jun 03, 2014 7:46 am
photos are not showing
Re: Single ATO
Posted: Tue Jun 03, 2014 7:54 am
by Christo
Why?
Re: Single ATO
Posted: Tue Jun 03, 2014 7:56 am
by Christo
They are Installed next to each other! The one higher than the other! With the wires pointing upwards! Hope that makes sense!
Re: Single ATO
Posted: Tue Jun 03, 2014 7:57 am
by Christo
How about now?
Re: Single ATO
Posted: Tue Jun 03, 2014 7:59 am
I think it has to do something with tapatalk
Re: Single ATO
Posted: Tue Jun 03, 2014 8:14 am
by Christo
Okay! But do you make sense of my description?
Re: Single ATO
Posted: Tue Jun 03, 2014 8:16 am
Yes, but according to your description, the code posted above is what you need.
Re: Single ATO
Posted: Tue Jun 03, 2014 8:40 am
by Christo
It does not work! It works kinda viceversa! When the level is low the relay switches off, when high it switches on! The ATO also keeps Timming out!
Re: Single ATO
Posted: Tue Jun 03, 2014 8:42 am
I think you have the float switches connected to the wrong ports.
Re: Single ATO
Posted: Tue Jun 03, 2014 9:03 am
by Christo
Its connected to the 2 Ports left of the pH probe!
Re: Single ATO
Posted: Tue Jun 03, 2014 9:09 am
Yes, but I think they are inverted.
Re: Single ATO
Posted: Tue Jun 03, 2014 9:14 am
by Christo
Inverted? Meaning?
Re: Single ATO
Posted: Tue Jun 03, 2014 9:23 am
ATO Low is on ATO High and ATO High is on ATO Low
Re: Single ATO
Posted: Tue Jun 03, 2014 9:32 am
by Christo
Nope! Checked that already!
Re: Single ATO
Posted: Tue Jun 03, 2014 10:42 am
Then you probably have them upside down
You can leave them mounted that way. Take the clip off and turn the float magnet upside down then put the clip back. That will reverse the behavior.
