wifi issues
Posted: Wed May 28, 2014 8:46 pm
Hi, Brand new to Reef Angel, just got my RA Plus Unit and Wifi attachment yesterday. All hardware is working correctly and I'm able to load code. I ran wifi setup successfully, uploaded wifi test code, but not able to connect with browser. The setup gave me 1.2.3.4:2000 which doesn't look right. When I connect the wifi to the head unit I see green blinking light, but when I type that address in firefox it just says connecting... then times out. I reran the wifi setup several times, each time I get the same results: 1.2.3.4:2000. When I bring up DHCP Client Table in the router settings, I don't see any reef angel connection. I do notice, however, that when I connect the wifi to the head unit, I can no longer connect to the internet with my macbook pro. I also can't login with ps3 which normally uses wifi as well. Looks like some kind of conflict. After I unplug reef angel wifi and restart the router I'm back up on the internet with Macbook pro and ps3. When I check DHCP client in the router settings, I see macbook pro on 192.168.1.121, but no reef angel, though I also don't see ps3 connection even though I'm logged in--which leads me to believe that reef angel could be up and running but how would I know what internal ip to check? But either way, it's still bringing down my wifi.
I'm using Cisco E3200 router with Windows 7 Desktop and Macbook Pro laptop connected through wifi (when Reef Angel's wifi is not plugged in).
Here's the code I saw when setting up the wifi:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM3
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM3
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM3
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 86328 3 wifly-GSX-400
< 4 74920 3 web_app-GSX-106
< 7 46632 3 wps_app-GSX-131
< 9 66240 3 eap_app-GSX-101
< 11 37282 0 web_config.html
< 21 512 0 link.html
< 24 -1 10 config
< 169 Free, Boot=2, Backup=2
< <4.00>
> set c c 0
< set c c 0
< AOK
< <4.00>
> set c r 0
< set c r 0
< AOK
< <4.00>
> set c o 0
< set c o 0
< AOK
< <4.00>
> set c i 3
< set c i 3
< AOK
< <4.00>
> set c s 1420
< set c s 1420
< AOK
< <4.00>
> set d n ww.reefangel
< set d n ww.reefangel
< AOK
< <4.00>
> set i h 198.171.134.6
< set i h 198.171.134.6
< AOK
< <4.00>
> set i r 80
< set i r 80
< AOK
< <4.00>
> set i f 0x6
< set i f 0x6
< AOK
< <4.00>
> set w j 1
< set w j 1
< AOK
< <4.00>
> set u m 2
< set u m 2
< AOK
< <4.00>
> set i p 2
< set i p 2
< AOK
< <4.00>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s Todd
< set w s Todd
< AOK
< <4.00>
> set w p b******1
< set w p b******1
< AOK
< <4.00>
< AOK
< <4.00>
< set ftp address 198.175.253.161
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Todd
< Chan=11
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=OK,renew=-6
< Boot=204
< Time=FAIL
< Links=1
< <4.00>
> get i
< get i
< IF=UP
< DHCP=SERVER
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
Found router Linksys Series Router E3200
Unable to setup port forwarding. This step will have to be done manually. For more information for your specific type of router, please visit ww.portforward
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 -1 10 config
< <4.00>
> set c c 0
< set c c 0
< AOK
< <4.00>
> set c r 0
< set c r 0
< AOK
< <4.00>
> set c o 0
< set c o 0
< AOK
< <4.00>
> set c i 3
< set c i 3
< AOK
< <4.00>
> set c s 1420
< set c s 1420
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> set i r 80
< set i r 80
< AOK
< <4.00>
> set i f 0x6
< set i f 0x6
< AOK
< <4.00>
> set w j 1
< set w j 1
< AOK
< <4.00>
> set u m 2
< set u m 2
< AOK
< <4.00>
> set i p 2
< set i p 2
< AOK
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s Todd
< set w s Todd
< AOK
< <4.00>
> set w p b******1
< set w p b******1
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Todd
< Chan=11
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=OK,renew=-6
< Boot=204
< Time=FAIL
< Links=1
< <4.00>
> get i
< get i
< IF=UP
< DHCP=SERVER
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
