Two code issues
Posted: Mon Jun 02, 2014 3:02 pm
There are two issues I'm having with my code right now. The first one is that I have a delayed start command in my code, but for some reason anytime I go into feeding mode my skimmer on port 7 starts up immediately instead of waiting for two minutes.
The next issue is with the WP10 I have on the daylight phase of the relay box. I sometimes find the powerhead turned off and I need to unplug it and plug it back in to get it started again. Not sure why it is doing that. Here is my current code:
ReefAngel.FeedingModePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port6Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port8Bit;
ReefAngel.StandardHeater( Port3,781,790 );
ReefAngel.StandardFan( Port1,791,801 );
ReefAngel.Relay.DelayedOn( Port7,2 );
ReefAngel.DosingPumpRepeat(Port4,0,360,300);
ReefAngel.WaterLevelATO(Port6,40,43,90);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.Off(Port7);
if (hour()>=8 && hour()<12)
ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) ); // Tidal Swell at 60% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(60,false) ); // Tidal Swell at 60% on anti-sync mode
else if (hour()>=12 && hour()<16)
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% + - 20 on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 80% + - 20 on anti-sync mode
else if (hour()>=16 && hour()<17)
ReefAngel.PWM.SetActinic( NutrientTransportMode(75,90,2000,false) ); // Nutrient Transport on anti-sync mode
else if (hour()>=17 && hour()<20)
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 75% + - 20 on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 75% + - 20 on anti-sync mode
else if (hour()>=20 && hour()<24)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,10,true) ); // Long pulse at 40% with 10s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,40,10,false) ); // Long pulse at 40% with 10s pulse on anti sync mode
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(0);
static byte WC_status=0;
0- No WC mode
1- WC started, so port5 is on
2- WC started and water has reached 5%, so port 5 is off and port2 is on
3- WC started and water has reached 43%, so port 2 is off
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE && WC_status==0)
ReefAngel.Relay.On(Port5);
WC_status=1;
if (ReefAngel.WaterLevel.GetLevel()<=5 && WC_status==1)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.On(Port2);
WC_status=2;
if (ReefAngel.WaterLevel.GetLevel()>=43 && WC_status==2)
ReefAngel.Relay.Off(Port2);
ButtonPress++;
WC_status=3;
if (ReefAngel.DisplayedMenu!=WATERCHANGE_MODE)
WC_status=0;
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
// Date and Time
0- No WC mode
WC_status=1;
WC_status=2;
ButtonPress++;
WC_status=3;
WC_status=0;
int x,y;
// Parameters
// Water Level
// Main Relay Box
// Date and Time
