Looking to get a reef angel but have questions
Posted: Sat Jun 07, 2014 12:18 am
I a setting up a 180 gal tank. It's been sitting unused for several years. It's a bit different than most, an Eco wheel from defunct aquatic engineers. Basically a ATS of sorts with no impeller pump for a return. Well it being different leads me more to the RA so I have the control to be different.
What I will need the controller to do: run air pump for return, run ATS light, temp control and ph monitor, ATO, 2 part dosing, 2 AI hydra 52's, 2wp40's, cooling fan(maybe). Wifi will be a must but may not make it on my initial list.
Questions
1 what is the quality of the RA dosing and ATO pumps? Read of some problems a year ago
2. What would I need above the start up package? Outside the dosing/ATO pumps and AI and jebao cables
3. Can it be expanded for 2 tanks if keep in close proximity?
4. Can it be programmed for random storms and tie in with both led and pumps(increased turbulence)
5. Is it easy to get the wp40's to sync to a back and forth wave motion?
6. For lunar cycle, can I do that with the AI lights as well or would I need the addon from RA?
7. Read of some earlier problems with probes as we'll. are those ironed out now?
I know this is a lot of questions but I am sure I could add more
Thanks for your help. I want to make a division quickly as I need to at least get a dosing setup ASAP on my 90 gal as I will be traveling soon.
Questions
