Temp display problem
Posted: Wed Jun 11, 2014 12:19 am
by Ridwaan
Hi..
I am new to Reef Angel and spent last night trying to figure it out...
I have managed to upload the code using the wizard but got an error so deleted the lines int he code that gave the error.
Anyways, I loaded the code and when I go ontot he controller itself and go to the temp readings that Ive setttup, its showing totally different values...
Example, I have set the temperature for the heater to switch on at 24.5 but ont he controller is shows 775???
I am now afraid to use this controller.
Yes, I did set it to celcius
please help
Re: Temp display problem
Posted: Wed Jun 11, 2014 6:21 am
Can you please post your code that you uploaded so we can look at it?
Posted: Mon Jun 23, 2014 4:11 am
by Ridwaan
Hi..
Here is my code
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit;
ReefAngel.StandardLights( Port1,9,0,19,0 );
ReefAngel.StandardLights( Port2,9,30,18,15 );
ReefAngel.StandardLights( Port3,11,0,18,0 );
ReefAngel.StandardHeater( Port4,245,255 );
ReefAngel.StandardHeater( Port5,245,255 );
ReefAngel.StandardFan( Port6,245,265 );
ReefAngel.StandardATO( Port7,40 );
ReefAngel.PHControl( Port8,670,650 );
ReefAngel.DCPump.SetMode( ReefCrest,100,10 );
ReefAngel.DCPump.ExpansionChannel[0] = None;
Posted: Mon Jun 23, 2014 7:50 am
Can you post a photo of the controller screen?
I think your code upload didn't happen.
