Issue with RO/DI Unit after swapping to a "better" membrane
Posted: Sun Jun 15, 2014 7:12 am
Hi everyone, sorry for the wall of a post, but I feel that detail is necessary in order to help others help me....
I have had a Precision Marine 4 Stage 150gpd RODI unit for about 4 years now. I always had low production numbers due to low water pressure and not having a booster pump(~70gpd). After moving into a new house I finally got a booster pump and expanded the RODI unit to 5 stage. With the booster pump I was producing maybe 90gpd, however I never worried about it since my post membrane TDS was 3-4.
I recently decided to replace my membrane after 4 years. I got the recommended 75 GPD Reverse Osmosis Membrane - Dow Filmtec 98% rejection rate from BRS....
Unfortunately, when I did the swap I threw away my old membrane right away and did not produce water till after garbage was already picked up.
Here is my problem.... Boosting 65psi I am producing ~130gpd with this 75 gpd membrane, thought this was awesome at first... but then I noticed I am also producing a very lousy 13-14 TDS post membrane.... Literally 25 gallons of product water used 70% of my DI resin.... I did a 2 hour flush on the membrane prior to sending any water through my DI resin.
My tap water TDS is on average 220-260... This means I should be in the ~4-5 TDS post membrane range with 98% rejection which is what I was previously getting with the 150gpd membrane with a lower rejection rate... But I am getting triple that 13-14....
BRS was amazing and even though I had my LFS order the pieces for me (trying to pass the money through a good LFS that is relatively new) they sent me a replacement RODI and flow restrictor without any confirmation that I actually purchased this from them. They just looked up my account and saw how much I have bought from them in the past and took my word for it... There is a reason when anything I need is on BRS I go through them...
After receiving the replacement membrane, swapping it out and flushing the membrane again for 2 hours before producing water... I received the same results... 13-14 TDS post membrane and ~130gpd... I spoke with them again and they recommended swapping out my membrane housing in case it had a hairline crack or it had swelled allowing water to bypass the membrane, I did this and I am still receiving the same 13-14 TDS post membrane...
I am completely at a loss at what is going on.. I do not get how a 150gpd with a 96% rejection rate was producing 3-4 TDS and now a higher rejection membrane is producing more water and a much higher TDS....
All my filters have been replaced.
My RO/DI stages are setup Like this and have been ran like this for about 2 years.
Stage 1 - 1 micron GE ROSAVE.Z DEPTH SEDIMENT FILTER
Booster pump - (I run sediment before in order to increase the life and efficiency of the pump, I do plan on buying a 6th stage to do a 5 micron pre-boost and move the 1 micron post boost)
Stage 2 - Refillable cartridge with Catalytic Activated Carbon for chloramines removal
Stage 3 - Pentek ChlorPlus Carbon Block
Stage 4 - 75gpd 98% rejection DowFilmtec Membrane
Automatic Shutoff Valve
Stage 5 - DI
Also, my automatic shut off valve is connected like this
Ports 1->2 (High pressure side) is my waste line.
Ports 3->(Screw side/Low pressure side) is my product water
Any ideas or help would be greatly appreciated...
Stage 5 - DI
