Relay expansion and 12v
- cody.sheridan-2008
Hi all,
I want to have 2 relays and also be able to have the 12v power control expansion. Is this possible to do with the wizard?
Cheers
Cody
Cheers
Cody
Cheers
Cody
Cody
Re: Relay expansion and 12v
Thanks rimai, how do I get them to display in the wizard so I can program them?rimai wrote:Sure you can
Up to 8 mix/match total
Cheers
Cody
Cody
I don't think the wizard can do that, but the code would be the same, except for the port you are using.
For example.
For the 1st box:
And for the 2nd Box:
And for the power control:
For example.
For the 1st box:
ReefAngel.Relay.On(Box2_Port1);
ReefAngel.Relay.On(Box3_Port1);
The 12v Power Control module shows up in the wizard like any other relay expansion.
So could I generate the code with the wizard and copy paste it in?rimai wrote:I don't think the wizard can do that, but the code would be the same, except for the port you are using.
For example.
For the 1st box:And for the 2nd Box:Code: Select all
And for the power control:Code: Select all
Cheers
Cody
Cody
This is my current stuff from the wizard, could you give an example of what it would look like if I had another relay with the same settings? Or just a few examples.
Much appreciated.
Cody
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.LightsOnPorts = Port2Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.Relay.On( Port3 );
ReefAngel.StandardLights( Port1,0,0,0,0 );
ReefAngel.StandardLights( Port2,15,0,21,0 );
ReefAngel.StandardHeater( Port4,240,250 );
ReefAngel.WavemakerRandom( Port5,60,100 );
ReefAngel.WavemakerRandom( Port6,60,100 );
ReefAngel.CO2Control( Port7,670,650 );
ReefAngel.StandardFan( Port8,270,280 );
ReefAngel.StandardATO( Box1_Port1,5400 );
ReefAngel.DCPump.SetMode( Lagoon,50,10 );
Cody
Cheers
Cody
Cody
I already posted a few examples a couple posts back.
Anywhere you see PortX, it refers to a port in the main box. All references to the 1st relay box have Box1_PortX.
Let's suppose you now have 2 relay boxes and 1 power control with this configuration:
ID1 - Relay Box
ID2 - Relay Box
ID3 - Power control
You can change the ID through the dip switch inside the module. Check the manual for more info.
So, all ports of the 2nd relay box would be called Box2_PortX and all ports of the power control would be called Box3_PortX.
Let's say you want to use your heater on the 1st port of the 2nd relay box. The code would be like this:
ID1 - Relay Box
ID2 - Relay Box
ID3 - Power control
ReefAngel.StandardHeater( Box2_Port1,240,250 );
Thanks Roberto, I think I have it now. Been playing around with my unit a bit.
Is it possible to get one of the small box's that come with the Relay expansion? I have the main box already... would prefer to spend the money on other expansions/attachments.
Cheers
Cody
Cody
