Page 1 of 2
wifi and setup issues
Posted: Sat Jun 21, 2014 3:27 pm
by heathd
Hey im sure I could look on the forums for hours and figure this out but im hoping someone can lead me in the right direction first. I connect the wifi attachment to the cables and run the program but its not letting me select the serial port. I purchased this RA unit from a friend it has way old software and stuff on it already I need to clean it all up and reinstall. having all sorts of problems connecting to it idk.
Re: wifi and setup issues
Posted: Sat Jun 21, 2014 3:29 pm
by heathd
When I plug the wifi controller in the green and blue lights flash so its hooked up to atleast have power should be doing something
Posted: Sat Jun 21, 2014 4:21 pm
If it is not showing up serial ports, you may not have the usb cable installed correctly.
If you go to device manager on your computer, do you see anything missing drivers?
Posted: Sat Jun 21, 2014 4:55 pm
by heathd
yah I installed a driver got it to do setup and setup the wifi attachment but its giving me this...
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM3
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM3
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM3
** ERROR - Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <4.00>
< FTP connecting to 198.175.253.161
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
< Set Factory Defaults
> reboot
< <4.00>
< reboot
Factory Settings Restored
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <4.00>
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 78524 3 WiFly_GSX-2.32
< 22 44704 3 wps_app
< 33 -1 10 config
< 34 78524 3 WiFly_GSX-2.32
< 54 49072 3 wps_app
< 67 -1 10 user
< 68 86328 3 wifly-GSX-400
< 166 Free, Boot=68, Backup=34
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s �MOTOROLA-C7B82
< set w s ?MOTOROLA-C7B82
< AOK
< <4.00>
> set w p a4a2d35a44912fefbeef
< set w p a4a2d35a44912fefbeef
< AOK
< <4.00>
< AOK
< <4.00>
< set ftp address 198.175.253.161
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=?MOTOROLA-C7B82
< Chan=6
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=10.1.10.20:2000
< NM=255.255.255.0
< GW=10.1.10.1
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <4.00>
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 33 -1 10 config
< 67 -1 10 user
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< Chan=6
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< NM=255.255.255.0
< GW=10.1.10.1
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <4.00>
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.00>
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <4.00>
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 33 -1 10 config
< 67 -1 10 user
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< Chan=6
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< NM=255.255.255.0
< GW=10.1.10.1
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
Posted: Sat Jun 21, 2014 4:58 pm
by heathd
No idea what I all just posted there but its not connecting also it wont let me update the firmware which I figured would need updating
Something is not right with the config file.
Try doing this:
Posted: Sat Jun 21, 2014 5:01 pm
by heathd
Also is there updates I should do to the controller software? Or can I do that after I get Wifi going to it?
Posted: Sat Jun 21, 2014 5:30 pm
by heathd
Really not sure if I'm that computer literate for this process.
Posted: Sat Jun 21, 2014 6:57 pm
by heathd
Yah been trying for 2 hrs to make that tera thing work no luck. Idk
Posted: Sat Jun 21, 2014 7:07 pm
by heathd
Also I was wondering how to set the time on the controller it is way off.
Posted: Sat Jun 21, 2014 7:16 pm
Which step are you getting hung up at?
Posted: Sat Jun 21, 2014 8:07 pm
by heathd
rimai wrote:Which step are you getting hung up at?
Idk what I'm doing wrong I downloaded everything. I think I put the right info into the macro. When I open that program it asks some stuff and I'm screwing that up I think.
Posted: Sat Jun 21, 2014 9:06 pm
What is it asking?
Posted: Sun Jun 22, 2014 5:09 pm
by heathd
Okay I got it going but now the portal function here on the web site keeps saying unreachable address. updated my profile so it has the right ip address and port. any ideas?
Posted: Sun Jun 22, 2014 7:18 pm
by heathd
So now I'm having trouble with the portal! It's a fight man. Lol. Anyways so I set my router ip address and portal so it stays and the portal is open. Still can't use the portal. 100%. Wanna be able to set time and update my software. Any ideas what's wrong? Modem support was looking for a subnet mask. Or something. Also the portal page keeps reseting my ip address when I try to connect so I have to go back into my profile every time.
Posted: Sun Jun 22, 2014 8:01 pm
Don't worry about changing the ip address. It is most likely auto correcting it for you.
You are probably trying to enter the local router ip address and it is not the one you want to use.
You want to use your outside ip address that is given to you by your internet provider.
You can see which one it is by visiting
http://www.whatismyip.com/ from any computer inside your home network.
Your problem is that you must setup port forwarding in your router. Routers are set to block all access and assume they are all harmful.
Posted: Sun Jun 22, 2014 10:02 pm
by heathd
Pretty sure I did that.i spent an hour on the phone with Motorola setting up the port stuff. Idk he thought there should be no issues. My dang firewall is even turned off still nothing.
Posted: Mon Jun 23, 2014 7:48 am
Try your port forwarding here:
Make sure to use port 2000
Posted: Mon Jun 23, 2014 9:11 am
by heathd
yahh still closed ugh dang router!
Posted: Mon Jun 23, 2014 11:27 am
by howaboutme
See if this website can help you.
http://portforward.com/english/routers/port_forwarding/
choose your router and follow the directions.
Posted: Mon Jun 23, 2014 4:08 pm
by heathd
Okay I'll mess with it later but what your saying is I need to open the incoming ip address and port? The one I have on the portal is showing me. I was messing with the other one.
Posted: Mon Jun 23, 2014 4:13 pm
by heathd
Looks like that link would be great. Except 30 bucks! Grrrr
Posted: Mon Jun 23, 2014 5:25 pm
by howaboutme
heathd wrote:Looks like that link would be great. Except 30 bucks! Grrrr
You're being distracted by the splash page after you click on your router brand. There is a "close" "x" at the top. Just carefully run through the site. It is FREE. Take your time so you totally comprehend everything.
Posted: Mon Jun 23, 2014 7:50 pm
by heathd
Ah thanks looking at it with my phone. Didn't notice thanks. I'll try later.
Posted: Mon Jun 23, 2014 11:33 pm
by heathd
yahh I went through that again I had done it last night its still not letting me in. is there something else I need on in a Motorola modem with Mediacom cable internet?
Posted: Tue Jun 24, 2014 12:38 am
by heathd
I paid 30 bucks for support with my modem did what they told me still not working. Port closed.
Posted: Tue Jun 24, 2014 5:45 am
by howaboutme
Can you tell us your exact Motorola modem model #? When I have time, I'll look it up and see if I can walk you through it. Or perhaps someone else w/ the same modem can too.
By the way, do you have a modem only or a modem/router? Also, do you have 2 of them wired together or just the one that came from your internet company?
Posted: Tue Jun 24, 2014 8:47 am
by heathd
It's a modem router combo. Sbg6580
Posted: Tue Jun 24, 2014 8:50 am
by heathd
It's just one combo modem router with cable Internet. Btw thanks for taking time to try and help here. I've been happy with everything so far just trying to get this last step done here has kicked my ass.
Posted: Tue Jun 24, 2014 9:43 am
by howaboutme
I just went to that website that I posted. I looked for your router and the instructions. One thing that I don't remember needing to do is create a static IP address. (I went to the instructions for my router and it suggests the same but I am pretty sure I didn't do it.)
So...for forwarding, I used as an example "Apache" since RA will not be in the list. The concept is the same. The only difference is that RA uses port 2000.
Try that and see what happens. It would help to post what your ISP or Motorola suggested you do for port forwarding too if the above doesn't work. Good luck!
