WiFi Help
Posted: Mon May 02, 2011 2:41 pm
by divingdon
Hello Group,
Before I get into the Issue that I'm experiencing please allow me to Thank the people who are responsible for an excellent reef controller with unlimited potential. My experience with the system has only been for a short time and by NO means can I write code but with the help of the RAGEN and Roberto it has been easier then I would have guessed.
The problem that I'm current having is twofold, 1st I cannot write any new codes because RAGEN will not run on the system dedicated to the REEF ANGEL in either the static mode or installed and I'm not really sure what happen to cause this problem but I can say the PC hasn't been modified or any new software added. But the Home network did get a new wireless router to allow me to secure the connection to the WiFi adapter. The WiFi adapter is seen when I use the setup codes.
This brings me to the 2nd part of the problem I cannot create a new code and I don’t know how to modify my current code that used the USB connection to log to the computer. If anyone can help with these issues I would be very grateful. I will post my current sketch for your review and comments please keep in mind this code is currently only controlling 6 meanwells and the main pump.
Thanks for your help
Don
// Autogenerated file by RAGen (v1.0.3.79), (03/19/2011 08:12)
// RA_031911_0812.pde
#define WavemakerSetup
#define ATOSetup
#define MetalHalideSetup
#define wifi
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel_TimerClass ParamTimer;
Give labels to your PWM channels
#define WhitePWM1 0
#define BluePWM1 1
#define WhitePWM2 2
#define BluePWM2 3
#define WhitePWM3 4
#define BluePWM3 5
byte PWMChannel[]={
0,0,0,0,0,0};
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "Reef Tank";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe3_label[] PROGMEM = "light";
prog_char relay1_label[] PROGMEM = "Main%20pump";
prog_char relay2_label[] PROGMEM = "skimmer";
prog_char relay3_label[] PROGMEM = "Heater%201";
prog_char relay4_label[] PROGMEM = "Heater%202";
prog_char relay5_label[] PROGMEM = "Always%20on";
prog_char relay6_label[] PROGMEM = "Chiller";
prog_char relay7_label[] PROGMEM = "LED%20Royal%20Blue";
prog_char relay8_label[] PROGMEM = "LED%20Cool%20White";
ReefAngel.PHMin=368;
ReefAngel.PHMax=655 ;
ReefAngel.FeedingModePorts = B00001111;
ReefAngel.WaterChangePorts = B00001111;
ReefAngel.OverheatShutoffPorts = B11001100;
ReefAngel.LightsOnPorts = B11000000;
ReefAngel.Relay.On(Port1);
// Initialize and start the Parameter timer
ParamTimer.SetInterval(15); // set interval to 15 seconds
ParamTimer.Start();
if ( ParamTimer.IsTriggered() )
ParamTimer.Start();
ReefAngel.PCLogging();
//This section calculates the slope
PWMChannel[WhitePWM1]=2.55*PWMSlope(12,15,21,00,0,30,60,PWMChannel[WhitePWM1]); // calculate slope for 0 to 50% starting at 12:30pm with duration of 60min, then from 50% to 0 from 17:00pm with duration of 60min
PWMChannel[BluePWM1]=2.55*PWMSlope(06,45,21,15,0,50,60,PWMChannel[BluePWM1]);
PWMChannel[WhitePWM2]=2.55*PWMSlope(12,16,21,00,0,30,60,PWMChannel[WhitePWM2]);
PWMChannel[BluePWM2]=2.55*PWMSlope(06,46,22,15,0,50,60,PWMChannel[BluePWM2]);
PWMChannel[WhitePWM3]=2.55*PWMSlope(12,17,21,00,0,30,60,PWMChannel[WhitePWM3]);
PWMChannel[BluePWM3]=2.55*PWMSlope(06,47,21,15,0,50,60, PWMChannel[BluePWM3]);
// this section sends the data to the PWM expansion module
PWMExpansion(WhitePWM1,PWMChannel[WhitePWM1]);
PWMExpansion(BluePWM1,PWMChannel[BluePWM1]);
PWMExpansion(WhitePWM2,PWMChannel[WhitePWM2]);
PWMExpansion(BluePWM2,PWMChannel[BluePWM2]);
PWMExpansion(WhitePWM3,PWMChannel[WhitePWM3]);
PWMExpansion(BluePWM3,PWMChannel[BluePWM3]);
void PWMExpansion(byte cmd, byte data)
Wire.beginTransmission(2); // transmit to device #2
Wire.send('$'); // sends $
Wire.send(cmd); // sends a value
Wire.send(data); // sends 255
Wire.endTransmission(); // stop transmitting
Re: WiFi Help
Posted: Mon May 02, 2011 4:42 pm
May I ask which software you were using to collect the data coming from RA using the USB cable?
Was it Dave's client suite?
Re: WiFi Help
Posted: Mon May 02, 2011 4:53 pm
by divingdon
I'm using the current version on Client suite 2.1 with lib version 8.5.14 on a XP system with a 1.6G processor and a 1gig ram
Re: WiFi Help
Posted: Mon May 02, 2011 5:13 pm
Oh, so I can help you with 2nd problem:
http://forum.reefangel.com/viewtopic.php?f=8&t=18
Dave goes over the new updates and how to make it work.
Re: WiFi Help
Posted: Mon May 02, 2011 6:45 pm
by divingdon
I removed and reinstalled the client software and enable Wifi in the ReefAngel_Features.h then tried to compile the sketch and was told is was too big so I disable the ReefAngel.ShowInterface(); and then compiled and still no luck connecting. I can ping the IP address and have it respond but no luck any other way. Maybe it will be easier to get the RAGEN working again and write a new sketch
Re: WiFi Help
Posted: Fri May 06, 2011 5:14 am
by divingdon
I final have gotten RAGEN to load and I believe that it is compiling correctly but I'm now getting this error
C:\Documents and Settings\My Documents\Arduino\libraries\ReefAngel_Wifi.cpp: In function 'void ProcessHTTP() ' :
C:\Documents and Settings\My Documents\Arduino\libraries\ReefAngel_Wifi.cpp:281: error: 'class ReefAngelClass' has no member named 'WM1port
C:\Documents and Settings\My Documents\Arduino\libraries\ReefAngel_Wifi.cpp: 285: error: 'class ReefAngelClass' has no member named 'WM2port
Clipboard does not contain a string
I have checked the library locations for Aurdino and RAGEN and they are the same. I'm not selecting any wavemakers, so I not understanding why the system is looking for them.
Please help
Don
Re: WiFi Help
Posted: Fri May 06, 2011 5:52 am
by YuppiWanna
did you convert to the development libraries?
http://www.reefangel.com/update/
Re: WiFi Help
Posted: Fri May 06, 2011 9:30 am
divingdon wrote:I final have gotten RAGEN to load and I believe that it is compiling correctly but I'm now getting this error
That's my bad on the error. This problem has been corrected in a pending/future release. I know somebody else encountered the same problem, which lead me to fixing it.
Here is the fix:
The solution to the problem is quite simple and will be in the next
release of my libraries.
Open this file inside a text editor (notepad works fine)
My Documents\Arduino\libraries\ReefAngel_Wifi\ReefAngel_Wifi.cpp
Locate the following block of code (starts on line 265):
                        case REQ_M_BYTE:
                        case REQ_M_INT:
                                // webmemoryloc is location
                                // weboption is value
                                if ( bHasSecondValue && (webmemoryloc >= 0) )
                                        // if we have a second value, we write the value to memory
                                        if ( reqtype == REQ_M_BYTE )
                                                InternalMemory.write(webmemoryloc, weboption);
                                                InternalMemory.write_int(webmemoryloc, weboption);
#ifdef WavemakerSetup     // ADD THIS LINE
                                        if ( (webmemoryloc == Mem_I_WM1Timer) || (webmemoryloc == Mem_I_WM2Timer) )
                                                // Restart wavemaker timers once they are set
                                                byte i = 1;
                                                byte p = ReefAngel.WM1Port;
                                                if ( webmemoryloc == Mem_I_WM2Timer )
                                                        i = 2;
                                                        p = ReefAngel.WM2Port;
                                                ReefAngel.Timer[i].Trigger = 0;
                                                ReefAngel.Timer[i].SetInterval(weboption);
                                                ReefAngel.Timer[i].Start();
                                                ReefAngel.Relay.On(p);
#endif  // WavemakerSetup   // ADD THIS LINE
                                        Serial.print("<M>OK</M>");
Add in the 2 lines that have // ADD THIS LINE in them. Those lines are
Your code will look like the above block of code.
Now save the file.
Then you can go back to Arduino and compile and upload to your controller.
This will solve the problem. It is already fixed in the upcoming release, but I do not know when I'll have the next release out. The problem was a minor oversight on my end. It only occurs when you do not have the wavemaker code added in.
This fix will work for you. If it does not, let me know and we can get a solution for you.
Re: WiFi Help
Posted: Fri May 06, 2011 1:47 pm
by divingdon
I made the changes and that error went away but a new one has arised.
C:\Documents and Settings\Administrator\My Documents\Ardunio\libraries\ReefAngel\ReefAngel.cpp: In member function ' void ReefAngelClass::ProcessButtonPressTimeouts() ' :
C:\Documents and Settings\Administrator\My Documents\Ardunio\libraries\ReefAngel\ReefAngel.cpp: 1800: error: no ,matching function for call to ' ReefAngelClass::Setupoption(int&, int&, int, int, int, const char [2], const char [15], constr char [1])'
C:\Documents and Settings\Administrator\My Documents\Ardunio\libraries\ReefAngel/ReefAngel.h: 164: note: candidates are: bool ReefAngelClass::Setupoption(int&, int&, int, int, byte, char*, char*,char*, char*)
Hope this helps you fix my issue.
thanks
Don
Re: WiFi Help
Posted: Fri May 06, 2011 3:06 pm
All of these errors you are finding have been corrected in a release that is not out yet.
This fix requires you to edit the ReefAngel.cpp file. Open up the file ReefAngel.cpp (inside the ReefAngel/ folder) and goto line 1800. You need to make sure it looks like this:
if ( SetupOption(v, y, 0, 3600, 4, "s", "", "Screen Timeout", "", "") )
The last comma is what is missing. So make line 1800 match the line above. Then save the file.
You should be able to compile and be up and running.
I apologize for any inconveniences this is causing....you have just beat me to getting my next release out. :)
Re: WiFi Help
Posted: Fri May 06, 2011 3:40 pm
by divingdon
That seemed to work but now when i compile the new sketch i'm being told that its too big. I have selected the following features
display images, setup extras, date/time setup, direct temp sensors and wifi
and i normal add version menu, and overheat setup and display led pwm,
so i'm not sure what is happeing now.
How soon will the new library be released?
Re: WiFi Help
Posted: Fri May 06, 2011 4:05 pm
The new library won't make a difference. There is just a limited amount of space on the controller for the code. The more features that are added in, the more space it will take up.
I can say that you won't need the Setup Extras or the Overheat Setup. Those 2 just give you menu entries to adjust the values. Once the values are set, they rarely change which is why they are an option. Using the Internal Memory PDE will set those values initially for you.
Date/Time setup takes up a lot of space. You shouldn't have a problem with the date & time once it is configured and setup. So you can set the date on the controller with a minimal PDE file and then upload your main PDE file to handle everything.
Also, you may want to remove the Display Images to help with the size.
Wifi uses a lot of space to handle all that it does, but you need to have that included in order to use your wifi module.
You may just have to experiment with removing some extra features to get the compile size down. Sometimes this just takes a little testing to get it to work properly unfortunately.
You might want to look at this page: https://github.com/curtbinder/ReefAngel ... Features.h
It gives you a little bit of information about how much space each feature requires.
Re: WiFi Help
Posted: Fri May 06, 2011 9:22 pm
by divingdon
Thanks Curt,
The WiFi is working now with the new sketch hopefully tomorrow the LED's will work properly with the PWMSlope command.
I just noticed and maybe other already have noticed the same thing. That when I'm in the feeding mode the Wifi doesn't stay connected. Is this the way it is supposed to be or did i miscode something??
But again Thanks for all of your help!!
Don
Re: WiFi Help
Posted: Sat May 07, 2011 3:41 pm
Correct.
Currently when you enter Feeding Mode or Water Change Mode, the controller does it's own thing and the wifi does not work. An improvement is in the works where the wifi and other monitoring actions are performed during Feeding Mode and Water Change Mode. In fact, check out this thread to give your input:
http://forum.reefangel.com/viewtopic.php?f=7&t=31
