Here is my entire code... A bit long... But I have been trying to remark as much stuff as possible to make it easy to find and understand. I have "//*****Begin ATO By Salinity Additions" Code sections and other code sections remarked...
// Initialize Alert variables
byte AlertManual=0;
byte AlertATOPump=0;
byte AlertNonCritical=0;
byte AlertCritical=0;
byte overheatflag=0;
byte atoflag=0;
byte iochannel0flag=0;
byte iochannel1flag=0;
byte iochannel2flag=0;
byte iochannel3flag=0;
byte iochannel4flag=0;
byte iochannel5flag=0;
//*****Begin Light Mask Timer Additions
byte LightMaskRemaining=0;
byte CurrentLightMask=0;
byte PreviousLightMask=255;
byte IgnoreMaskDuration; //manual switch to disable automatic Light Mask timeout (0=normal, != 0 = Ignore Light Mask timeout)
byte MaskDuration; //Mask timer length in minutes 0 - 255
long TargetMillis; //End of Timer in Millis
long CurrentMillis; //Current Time in Millis
long InitialMillis; //Start Time in Millis
//*****End Light Mask Timer Additions
//*****Begin reporting of Maximum\Minimum Temperature on probe T1 Additions
int T1LowTemp=999;
int T1HighTemp=1;
int T1Read=1;
//*****End reporting of Maximum\Minimum Temperature on probe T1 Additions
//*****Begin WaterChange Additions
// skimmer port
byte SkimmerPort = Port4;
// return port
byte ReturnPort = Port3;
// sump drain port
byte SumpDrainPort = Port8;
// SaltWater brute pump
byte SWBrutePort = Port7;
// Timer for countdowns
TimerClass tm;
//*****End WaterChange Additions
byte ATOBrutePort = Port2;
//*****End ATO By Salinity Additions
//*****Begin Custom IO Expander Additions
byte CustomIOExpander = 255;
//*****End Custom IO Expander Additions
//*****Begin Custom Menu Additions
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Mask LED's On";
prog_char menu2_label[] PROGMEM = "Mask LED's Off";
prog_char menu3_label[] PROGMEM = "Mask LED's Clear";
prog_char menu4_label[] PROGMEM = "Water Change";
prog_char menu5_label[] PROGMEM = "Clear ATO Timeout";
prog_char menu6_label[] PROGMEM = "Overheat Clear";
prog_char menu7_label[] PROGMEM = "PH Calibration";
prog_char menu8_label[] PROGMEM = "Date / Time";
PROGMEM const char *menu_items[] =
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label,
//*****End Custom Menu Additions
//_Compiled_With_Libs_Version_1.1.0
InternalMemory.write(110, 110);
//_Running_Config_Revision_108
InternalMemory.write(111, 108);
//*****Begin Custom Menu Additions... Initialize Custom Menu
if (InternalMemory.read(199) !=0) (InternalMemory.write(199, 0)); //sets the controller to non masked LED mode upon reboot.
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit | Port6Bit;
// Ports that should always be on/off at startup
ReefAngel.Relay.On( Port3 );//Turns 180G Return Pump ON if controller reboots
ReefAngel.Relay.Off( Port2 );//Turns 180G RO/DI Topoff OFF if controller reboots
ReefAngel.Relay.Off( Port7 );//Turns 180G SW Topoff OFF if controller reboots
ReefAngel.Relay.Off( Port8 );//Turns 180G Sump Drain OFF if controller reboots
ReefAngel.Relay.On( Box1_Port5 );//Turns 20GH QT Return Pump ON if controller reboots
ReefAngel.Relay.On( Box1_Port6 );//Turns 29G QT Return Pump ON if controller reboots
ReefAngel.Relay.On( Box1_Port7 );//Turns 20GH QT MaxiJet Pump ON if controller reboots
ReefAngel.Relay.On( Box1_Port8 );//Turns 29G QT MaxiJet Pump ON if controller reboots
ReefAngel.CustomVar[0]=0;
ReefAngel.CustomVar[1]=0;
ReefAngel.CustomVar[2]=0;
ReefAngel.CustomVar[3]=0;
ReefAngel.CustomVar[4]=0;
ReefAngel.CustomVar[5]=0;
ReefAngel.CustomVar[6]=0;
ReefAngel.CustomVar[7]=0;
ReefAngel.StandardFan( Port1,790,820 );
ReefAngel.WavemakerRandom( Port5,30,100 );
ReefAngel.StandardHeater( Port6,750,760 );
ReefAngel.StandardHeater( Box1_Port3,750,760 );
ReefAngel.StandardHeater( Box1_Port4,750,760 );
//LightMaskRemaining = ( TargetMillis - CurrentMillis ) / 3600000;//Display Light Mask Time Remaining in Hours
LightMaskRemaining = ( TargetMillis - CurrentMillis ) / 60000;//Display Light Mask Time Remaining in Minutes
//LightMaskRemaining = ( TargetMillis - CurrentMillis ) / 1000;//Display Light Mask Time Remaining in seconds
CurrentLightMask = InternalMemory.read(199);//reads current light mask setting
MaskDuration = InternalMemory.read (198); //Mask timer length in minutes 0 - 255 (0:00 - 4:15)
IgnoreMaskDuration = InternalMemory.read (197); //manual switch to disable automatic Light Mask timeout (0=normal, != 0 = Ignore Light Mask timeout)
CurrentMillis = millis();//update the timer to the current count
// Removes LED's from a "MASKED" State
if ( CurrentLightMask == 0 )
ReefAngel.PWM.SetChannel( 0, PWMParabola(14,0,23,59,1,100,1) ); //Sets LED Drivers on Ch0 to Parabola math
ReefAngel.PWM.SetChannel( 1, PWMParabola(14,0,23,59,1,100,1) ); //Sets LED Drivers on Ch1 to Parabola math
ReefAngel.PWM.SetChannel( 3, PWMSlope(2,0,7,30,0,50,0,0) ); //Opens/closes 5V relay on Ch3 that shorts\opens dimmer leads on Ch0 LED driver to turn Driver on/off
ReefAngel.PWM.SetChannel( 4, PWMSlope(0,0,14,0,0,50,0,0) ); //Opens/closes 5V relay on Ch4 that shorts\opens dimmer leads on Ch1 LED driver to turn Driver on/off
ReefAngel.StandardLights( Box1_Port1,13,0,23,0 ); //turns QT Light schedule on if not masked off
ReefAngel.StandardLights( Box1_Port2,13,0,23,0 ); //turns QT Light schedule on if not masked off
if ( PreviousLightMask != CurrentLightMask )//Checks if the light mask setting has been changed
//Checks if light mask value has been set to an invalid value by direct memory access and clears (sets to 0) mask if not valid
if ( CurrentLightMask > 2 )
InternalMemory.write(199, 0); //clears light mask if value is not valid.
// MASKS LED's Off
if ( CurrentLightMask == 1 )
TargetMillis = CurrentMillis + ( MaskDuration * 60000 ); //Set the duration of the mask timer in minutes ( 1 - 255 )
ReefAngel.PWM.SetChannel( 0, 0 ); //Sets LED Drivers on Ch0 to 0%
ReefAngel.PWM.SetChannel( 1, 0 ); //Sets LED Drivers on Ch1 to 0%
ReefAngel.PWM.SetChannel( 3, 50 ); //closes 5V relay on Ch3 that shorts dimmer leads on Ch0 LED driver to turn Driver off
ReefAngel.PWM.SetChannel( 4, 50 ); //closes 5V relay on Ch4 that shorts dimmer leads on Ch1 LED driver to turn Driver off
ReefAngel.Relay.Off( Box1_Port1 ); //turns QT Lights OFF if masked off
ReefAngel.Relay.Off( Box1_Port2 ); //turns QT Lights OFF if masked off
// MASKS LED's On
if ( CurrentLightMask == 2 )
ReefAngel.PWM.SetChannel( 0, 100 ); //Sets LED Drivers on Ch0 to 100%
ReefAngel.PWM.SetChannel( 1, 100 ); //Sets LED Drivers on Ch1 to 100%
ReefAngel.PWM.SetChannel( 3, 0 ); //Opens 5V relay on Ch3 that removes short on dimmer leads on Ch0 LED driver to turn Driver on
ReefAngel.PWM.SetChannel( 4, 0 ); //Opens 5V relay on Ch4 that removes short on dimmer leads on Ch1 LED driver to turn Driver on
ReefAngel.Relay.On( Box1_Port1 ); //turns QT Lights ON if masked on
ReefAngel.Relay.On( Box1_Port2 ); //turns QT Lights ON if masked on
PreviousLightMask = CurrentLightMask;
if ( CurrentLightMask != 0 )// Checks if lights are masked on or off
if ( IgnoreMaskDuration == 0 )//Checks if Light mask timer ignore byte is active
if ( CurrentMillis > TargetMillis )//checks if Light mask timeout has expired.
InternalMemory.write(199, 0); //clears forgotten light mask due to timeout.
CurrentMillis = 0;//sets back to 0 when not being used to prevent display from counting negative time when Light mask is cleared.
TargetMillis = 0;//sets back to 0 when not being used to prevent display from counting negative time when Light mask is cleared.
T1Read = ReefAngel.Params.Temp[T1_PROBE];
if (T1Read !=0)//Debounce for Low Temperature reading 0 at startup
T1LowTemp = min(T1LowTemp, T1Read);//Tracks Low Temperature
T1HighTemp = max(T1HighTemp, T1Read);//Tracks High Temperature
iochannel0flag = ! ReefAngel.IO.GetChannel( 0 );
iochannel1flag = ! ReefAngel.IO.GetChannel( 1 );
iochannel2flag = ! ReefAngel.IO.GetChannel( 2 );
iochannel3flag = ! ReefAngel.IO.GetChannel( 3 );
iochannel4flag = ! ReefAngel.IO.GetChannel( 4 );
iochannel5flag = ! ReefAngel.IO.GetChannel( 5 );
AlertManual = InternalMemory.read (112); //Manul Switch to turn on buzzer
AlertATOPump = ReefAngel.Relay.Status(Port2);
AlertNonCritical = atoflag + iochannel2flag + iochannel3flag + iochannel4flag + iochannel5flag;
AlertCritical = AlertManual + AlertATOPump + overheatflag + iochannel0flag + iochannel1flag;
if ( AlertNonCritical >= 1 ) AlertNonCritical = 25;
if ( AlertCritical >= 1 ) AlertCritical = 25;
if ( AlertNonCritical >= 1 ) ReefAngel.PWM.SetActinic(millis()%60000<100?AlertNonCritical:0);
if ( AlertNonCritical >= 1 ) ReefAngel.PWM.SetDaylight(millis()%60000<100?AlertNonCritical:0);
if ( AlertCritical >= 1 ) ReefAngel.PWM.SetActinic(millis()%300<100?AlertCritical:0);
if ( AlertCritical >= 1 ) ReefAngel.PWM.SetDaylight(millis()%300<100?AlertCritical:0);
ReefAngel.CustomVar[0]=InternalMemory.read(ATO_Exceed_Flag);
ReefAngel.CustomVar[1]=InternalMemory.read(Overheat_Exceed_Flag);
ReefAngel.CustomVar[2]=CustomIOExpander;
ReefAngel.CustomVar[3]=AlertManual;
ReefAngel.CustomVar[4]=LightMaskRemaining;
ReefAngel.CustomVar[5]=AlertNonCritical;
ReefAngel.CustomVar[6]=AlertCritical;
ReefAngel.CustomVar[7]=ATOBrutePort;
if ( ReefAngel.CustomVar[0]== 1 )
ReefAngel.Relay.RelayMaskOff=~(Port4Bit);
//*****Begin WC Additions
// If menu equals waterchange mode
// then we start the automatic water change
// Otherwise we ignore and proceed
AutoWaterChange();
//*****End WC Additions
if (ReefAngel.Params.Salinity<300)
ATOBrutePort=Port7;
ATOBrutePort=Port2;
ReefAngel.StandardATO(ATOBrutePort,40 );
if (iochannel2flag == 1)
ReefAngel.Relay.RelayMaskOff=~(Port7Bit);
if (iochannel4flag == 1)
ReefAngel.Relay.RelayMaskOff=~(Port2Bit);
ReefAngel.Portal( "00Warpig00" );
//Mask Lights On. Forces Lights's On Full Blast
void MenuEntry1()
InternalMemory.write(199, 2);
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, " ");
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Mask Lights On"); waitForTime(2);
//Mask Lights Off. Forces Lights Off
void MenuEntry2()
InternalMemory.write(199, 1);
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Mask Lights Off"); waitForTime(2);
//Mask Lights Clear. Remove Light Masking Returns Lights to normal schedule
void MenuEntry3()
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Mask Lights Clear"); waitForTime(2);
//Start Waterchange Mode
void MenuEntry4()
//Clear ATO Timeout Flag
void MenuEntry5()
ReefAngel.ATOClear();
//Clear Overheat Flag
void MenuEntry6()
ReefAngel.OverheatClear();
//Calibrate PH Probe
void MenuEntry7()
ReefAngel.SetupCalibratePH();
//Set clock Date & Time
void MenuEntry8()
ReefAngel.SetupDateTime();
//*****Begin Water Change Additions
void AutoWaterChange()
// auto water change mode
// Display Starting Water Change"
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Starting Water Change"); waitForTime(3);
// Check Saltwater BRUTE for sufficient saltwater on IO Module Port2
if ( isSWBruteEmpty() )
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Not Enough Saltwater"); waitForTime(3);
//Abort Water Change if insufficient saltwater
// Handles the cleanup to return to the main screen
ReefAngel.DisplayedMenu = DEFAULT_MENU;
DrawCustomGraph();
return;
//Display Disabling ATO Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Disabling ATO Pump"); waitForTime(3);
// turn off ATO pump port to prevent ATO from trying to fill a sump being drained intentionally
//Display Stopping Skimmer
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stopping Skimmer"); waitForTime(3);
// turn off the skimmer port
ReefAngel.Relay.Off(SkimmerPort);
ReefAngel.Relay.Write();
//Display Skimmer Draining
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Skimmer Draining"); waitForTime(3);
// wait for 1 minute
waitForTime(60);
//Display Skimmer Done Draining
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Skimmer Done Draining"); waitForTime(3);
//display Stopping Return Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stopping Return Pump"); waitForTime(3);
//Stop Return Pump
ReefAngel.Relay.Off(ReturnPort);
//Display Draining To Sump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Draining To Sump"); waitForTime(3);
//display Sump Filling
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Filling"); waitForTime(3);
// wait for IO Mod Port 1 to be active
waitForIOChannel(1);
//display Sump Is Full
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Is Full"); waitForTime(3);
//Display Sump Settling
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Settling"); waitForTime(3);
// wait for sump to settle
waitForTime(30);
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Settled"); waitForTime(3);
// display Draining Sump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Start Draining Sump"); waitForTime(3);
//turn on sump drain pump
ReefAngel.Relay.On(SumpDrainPort);
//display Sump Draining
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Draining"); waitForTime(3);
// wait for sump empty port active, IO Mod Port 0
waitForIOChannel(0);
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Is Empty"); waitForTime(3);
//display Stopping Sump Draining
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stopping Sump Drain"); waitForTime(3);
// turn off sump drain
ReefAngel.Relay.Off(SumpDrainPort);
waitForTime(30);
//display Sump Settled
//display Starting Saltwater Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Start Saltwater Pump"); waitForTime(3);
//turn on Saltwater Pump
ReefAngel.Relay.On(SWBrutePort);
//display Saltwater Pumping
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Saltwater Pumping"); waitForTime(3);
// wait for sump full float switch active, IO Mod Port 1
//display Stop Saltwater Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stop Saltwater Pump"); waitForTime(3);
// turn off sw brute pump
ReefAngel.Relay.Off(SWBrutePort);
//diasplay Sump is Full
waitForTime(30);
//display Starting Return Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Starting Return Pump"); waitForTime(3);
// turn on return pump
ReefAngel.Relay.On(ReturnPort);
//display Return Pump Started
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Return Pump Started"); waitForTime(3);
//display Normalizing Waterlevel
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Normalizing Waterlevel"); waitForTime(3);
//waiting 2 minutes for waterlevel to normalize
waitForTime(120);
//display Starting Skimmer
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Starting Skimmer"); waitForTime(3);
//turn on skimmer
ReefAngel.Relay.On(SkimmerPort);
//display Normalizing Skimmer
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Normalizing Skimmer"); waitForTime(3);
//wait for 2 minutes for skimmer to normalize
waitForTime(120);
//display Skimmer Normalized
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Skimmer Normalized"); waitForTime(3);
//display Enabling ATO Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Enabling ATO Pump"); waitForTime(3);
//Enable ATO pump
ReefAngel.Relay.RelayMaskOff = B11111111;
//display Water Change Complete
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Water Change Complete"); waitForTime(3);
DrawCustomGraph();
bool isSWBruteEmpty()
// check status of IO Mod Port 2
if ( ! ReefAngel.IO.GetChannel(2) )
return true;
return false;
void waitForTime(int seconds)
bool done = false;
tm.SetInterval(seconds);
tm.Start();
int t = tm.Trigger - now();
do
// check the wifi interface
// wait for specified seconds
if ( (t >= 0) && ! tm.IsTriggered() )
wdt_reset();
delay(200);
done = true;
} while ( !done );
return;
void waitForIOChannel(byte channel)
// TODO complete this function
do
wdt_reset();
// display something on screen
delay(200);
// TODO check the IO channel logic
} while ( ReefAngel.IO.GetChannel(channel) );
//*****End Water Change Additions
byte expanderRead()
byte _data=0;
Wire.requestFrom(0x27, 1);
if(Wire.available())
_data = Wire.read();
CustomIOExpander = _data;
delay(10);
return _data;
boolean expanderReadGetChannel(byte channel)
return bitRead(expanderRead(),channel);
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Ch : " );
y += 10;
// I/O Expansion
byte bkcolor;
x = 14;
y = 34;
ReefAngel.LCD.DrawMonitor( 15, 44, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 44, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,73, "SAL:" );//Display Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,82, "LMTR:" );//Display Light Mask Time Remaining
// ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, " Hours." );//Clear screen video from data location before new data draw
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, " Min." );//Clear screen video from data location before new data draw
// ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, " Sec." );//Clear screen video from data location before new data draw
// ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, ( TargetMillis - CurrentMillis ) / 3600000 );//Display Light Mask Time Remaining in Hours
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, ( TargetMillis - CurrentMillis ) / 60000 );//Display Light Mask Time Remaining in Minutes
// ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, ( TargetMillis - CurrentMillis ) / 1000 );//Display Light Mask Time Remaining in seconds
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,60,73, "L:" );//Display Low Temperature
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,96,73, "H:" );//Display High Temperature
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,73, ReefAngel.Params.Salinity );//Display Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,72,73, T1LowTemp );//Display Low Temperature
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,108,73, T1HighTemp );//Display High Temperature
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 104, TempRelay );
