Where is CustomMainScreen_RopeLeakDetector ?
Posted: Thu Jul 03, 2014 9:54 pm
by Dan in Qatar
Hi,
I just purchased the Rope Leak Detector expansion kit. Upon following the instructions in the Quick Start Manual, I cannot find "CustomMainScreen_RopeLeakDetector" under Example Codes.
Where is this code?
DanInDoha
Re: Where is CustomMainScreen_RopeLeakDetector ?
Posted: Fri Jul 04, 2014 8:19 am
Just use the wizard. It's what you will end up doing anyway.
Posted: Tue Jul 08, 2014 1:07 pm
by newtoke
I used the wizard and the only screen I see is in the menus to clear a leak. Is there a main screen notification as well?
Posted: Tue Jul 08, 2014 4:04 pm
Yes, when leak is detected.
If you scroll the screens, you will also see the Leak status together with the ATO statuses.
Just use the joystick and move left or right.
