Arduino Sketch To Big Issue ??? HELP !
Posted: Sat Jul 05, 2014 3:24 am
by jcondello
Hi Ive been compiling code for a while now and making changes to setting etc. and uploading with no issue, now i am getting an error when compiling "sketch to big" please help here is the code below, but nothing has changed since last update ??
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port2,260,265 );
ReefAngel.StandardFan( Port8,270,275 );
ReefAngel.DosingPumpRepeat( Box1_Port1,0,1440,1 );
ReefAngel.DosingPumpRepeat( Box1_Port2,5,1440,8 );
ReefAngel.Portal( "jcondello","NUMBER7" );
int x,y;
// I/O Expansion
byte bkcolor;
x = 14;
y = 8;
for ( int a=0;a<6;a++ )
ReefAngel.LCD.DrawCircleOutline( x+(a*20),y,4,COLOR_MEDIUMORCHID );
if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
ReefAngel.LCD.FillCircle( x+(a*20),y,2,bkcolor );
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 19, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 19, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,49,53, "SAL:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,73,53, 10 );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,68, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,68, 100 );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,68, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,68, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 82, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 99, TempRelay );
// Date and Time
Re: Arduino Sketch To Big Issue ??? HELP !
Posted: Sat Jul 05, 2014 10:43 am
by Sacohen
Do you have the RA or RA+?
I see the DCPumps in there. Did you just add that?
The DCPump code added a lot to the libraries and most of the time that is the cause of your problem.
You may need to upgrade to the RA+ or go back to an older library.
Posted: Sun Jul 06, 2014 6:29 am
by jcondello
I do have the ra+ but the issue is when compiling not uploading ??
Posted: Sun Jul 06, 2014 6:32 am
by Sacohen
Make sure. You have the Aurduino ser to RA + and not RA. It may have gotten changed by accident.
Posted: Sun Jul 06, 2014 6:49 am
by jcondello
yes thank you thats all it was
Posted: Sun Jul 06, 2014 6:52 am
by jcondello
can you help put with setting the RA to send data to the portal i have added the user name & portal Key to the code but have not had any luck with it, i can use the portal switching on/off but cant get the ra to send data, i also have the Wifi dongle attached & work thank you
Posted: Sun Jul 06, 2014 6:53 am
by jcondello
never mind just got it going thank you !
Posted: Sun Jul 06, 2014 6:58 am
by Sacohen
No problem. It's usually something simple like that.
