WP40 confusion
Fanienel
WP40 confusion
Post by Fanienel »
Hi,
I am new to this so please excuse the basic question:
I have one WP40 connected to the RA using a dimmer port. I would like a gentle flow during the night, a more vigorous flow in the day with a hour of nutrient transport. Here is the code:
    ReefAngel.StandardHeater( Port3,250,270 );
    ReefAngel.StandardHeater( Port4,250,270 );
    ReefAngel.Relay.DelayedOn( Port5,10 );
    ReefAngel.WavemakerRandom( Port6,60,100 );
    ReefAngel.DCPump.SetMode( ReefCrest,30,30 );
   // ReefAngel.DCPump.ActinicChannel = None;
    if (hour()>=21 || hour()<8)
     //       ReefAngel.RF.UseMemory=false;
            ReefAngel.DCPump.SetMode(Lagoon,30,90);
      //      ReefAngel.DCPump.DaylightChannel = Sync;
            ReefAngel.Relay.Off( Port6 );
    else if (hour()>=9 && hour()<10)
            ReefAngel.DCPump.SetMode( NutrientTransport,60,10 );
            ReefAngel.DCPump.SetMode(ReefCrest,40,30);
Now:
[*]Could I have a speed as low as 30 in the Lagoon mode? - The pump does not run.
[*]On the RA display and the portal I get an RF Expansion module readout with Vortech and Radion data as wel as a DC Pump readout. Did I somehow switched this on in the code?
[*]What does
and
do?
Thank you
Fanie
Re: WP40 confusion
If you mention ReefAngel.RF in your code. Even if it's commented out, the compiler will think you have that module and enable it. No harm though, just will use up more memory. 30% is probably too low. The WP pumps usually cut out if too low a voltage and it's right around there. Each one varies slightly.
Re: WP40 confusion
Fanienel wrote: [*]What does
This line tells the DCPump library that your Daylight Channel pump is in Sync mode. If you had more than one pump, you would usually want one pump in Sync and one in Anti-Sync. With only one pump it doesn't matter, but you can't put None or nothing would happen. You should uncomment this, could be part of your problem.
Fanienel wrote: and
do?
If you were using the RF module, it would tell the code to use the values you set and not what is stored in memory. There is a similar method for the DCPump library. ReefAngel.DCPump.UseMemory. It does the same thing and in your case you do want to set it to false since you are overriding the defaults with your time schedule.
Fanienel
Re: WP40 confusion
Post by Fanienel »
Thank you Lee
