Skimmer not coming back on after feed mode
Posted: Thu Jul 17, 2014 1:20 pm
by 89delta
So I snagged a bit of code from Paulturner911 to include a delay after feed mode is triggered while the WP's are in NTM. After 15min the skimmer is supposed to turn back on but doesn't.I have marked the section in red.Any ideas?
Sorry would have used the code tag but doesnt allow color in the font.
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { Lagoon, Else, ReefCrest, TidalSwell, ShortPulse, LongPulse, NutrientTransport };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
if (now()-feeding<900) {
// First 15 minutes after feeding mode stops. Skimmer is off
ReefAngel.Relay.Off(Port3);
// First 15 minutes after feeding mode stops. Smart_NTM
ReefAngel.DCPump.Mode=NutrientTransport;
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
// Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
// Night mode (go to 30%)
ReefAngel.DCPump.Mode=Constant;
ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
if (modes[rmode]==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true ); // ElseMode on sync mode, Portal Speed Setting +/- 25%
} else {
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
} else {
Re: Skimmer not coming back on after feed mode
Posted: Thu Jul 17, 2014 3:06 pm
Can you post your full code (with the code tags?) need to see how your turning the port on in normal mode...
Posted: Thu Jul 17, 2014 3:20 pm
by 89delta
Thanks Lnevo....here is the current code i am using.
//#include <WiFiAlert.h>
//#include <RA_PCA9685.h>
#include <SunLocation.h>
#define NUMBERS_8x16
#define I2CPWM_PCA9685      0x40
SunLocation sl;
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
////// Memory Locations used by all formulas
#define Mem_B_AcclDay  100
// Note - 100 represents the hard coded Memory location used for this variable
// not the value for the variable.
// This variable represents the current day in Acclimation Cycle. Set this value to the same
// number of days as your AcclDuration to begin the acclimation cycle or set it to 0 to use
// your normal dimming end% values.
#define Mem_B_AcclDuration  101 // Set this value to how many days you want your acclimation cycle to take.
#define Mem_B_SlopeStart  102 // Set this to your desired starting acclimation end%.
/////// Memory Locations used by Blue Formula
#define Mem_B_AcclStartEndBlue  105    // Acclimation starting Slope end%
#define Mem_B_SlopeEndBlue  106    // slope End%
////// Memory Locations used by White Formula
#define Mem_B_AcclStartEndWhite  110 // Acclimation starting Slope end%
#define Mem_B_SlopeEndWhite  111    // Slope End%
// Define Portal Variables
#define Var_AcclDay      0
//#define Var_DPump1       1
//#define Var_DPump2       2
//#define Var_Tide         3
//#define Var_TideMode     4
//#define Var_LogATO       5
//#define Var_WCVol        6
#define Var_weekday        7
void DrawCustomMain() {  //5,14
  char buf[16];
  byte acclDay = InternalMemory.read(Mem_B_AcclDay);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 6, 4, " Martin's BC29");
  ReefAngel.LCD.DrawDate(6, 118);
  // Temp and PH
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,10,14,"Temp:");
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,85, 14, "PH:");
  ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 48, 16, buf);
  ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(T1TempColor, DefaultBGColor, 10, 22, buf, Num8x16);
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 85, 22, buf, Num8x16);
  ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, 48, 25, buf);
  //ATO
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,40,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,40,"Low",Font8x16);
    ReefAngel.LCD.FillCircle(55,43,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(55,43,5,COLOR_RED);
  if (ReefAngel.LowATO.IsActive()) {
    ReefAngel.LCD.FillCircle(70,43,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(70,43,5,COLOR_RED);
  //Sunrise/Sunset Times
  ReefAngel.LCD.DrawText(0,255,5,52,"Rise:");
  ReefAngel.LCD.DrawText(0,255,38,52,(sl.GetRiseHour()));
  ReefAngel.LCD.DrawText(0,255,43,52,":");
  ReefAngel.LCD.DrawText(0,255,48,52,(sl.GetRiseMinute()));
  ReefAngel.LCD.DrawText(0,255,65,52,"Set:");
  ReefAngel.LCD.DrawText(0,255,88,52,(sl.GetSetHour()));
  ReefAngel.LCD.DrawText(0,255,100,52,":");
  ReefAngel.LCD.DrawText(0,255,105,52,(sl.GetSetMinute()));
  //Cloud Start and Lightning Start
    //ReefAngel.LCD.DrawText(0,255,5,62,"C");
    //ReefAngel.LCD.DrawText(0,255,11,62,"00:00");
    //ReefAngel.LCD.DrawText(0,255,45,62,"L");
    //ReefAngel.LCD.DrawText(0,255,51,62,"00:00");
  //Moon Phase
  ReefAngel.LCD.DrawText(0,255,5,72,"Moon:");
  ReefAngel.LCD.DrawText(0,255,35,72,MoonPhaseLabel());
  // Display Acclimation timer
  ReefAngel.LCD.DrawText(0,255,5,82,"Acclimation Day:");
  ReefAngel.LCD.DrawText(0,255,105,82,acclDay);
  // Display LED %
  ReefAngel.LCD.DrawText(0,255,12,92, "CW:");
  ReefAngel.LCD.DrawText(197,255,32,92, ReefAngel.PWM.GetDaylightValue());
  ReefAngel.LCD.DrawText(0,255,72,92, "RB:");
  ReefAngel.LCD.DrawText(3,255,92,92, ReefAngel.PWM.GetActinicValue());
  // Display Relays
  ReefAngel.LCD.DrawOutletBox(12, 102, TempRelay);
    //ReefAngel.Use2014Screen();  // Let's use 2014 Screen
    ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port7 );
  sl.Init(-21.285833, 150.999722); // In decimal numbers (i.e. -18.285833, 147.699722)
  sl.SetOffset(11,0,11,0); // rise_hour, rise_seconds, set_hour, set_seconds
  randomSeed(now()/SECS_PER_DAY);
  //if (InternalMemory.read(Mem_B_ResetMemory))
    //init_memory();
    //ReefAngel.Relay.Set(Port1,weekday()==1 && hour()==8 && minute()==0&&second()<5);
    byte weekday();
    ReefAngel.CustomVar[Var_weekday]=weekday();
    ReefAngel.StandardHeater( Port2,779,790 );
    ReefAngel.StandardFan( Port7,779,790 );
    ReefAngel.DosingPumpRepeat1( Port4 );
    ReefAngel.DosingPumpRepeat2( Port5 );
    ReefAngel.StandardATO( Port6 );
    ReefAngel.PWM.SetChannel( 0, MoonPhase()/3 );
    ReefAngel.PWM.SetChannel( 1, MoonPhase()/3 );
    //ReefAngel.DCPump.UseMemory = true;
    //ReefAngel.DCPump.SetMode( rmode );
    ReefAngel.DCPump.ExpansionChannel[0] = None;
    ReefAngel.DCPump.ExpansionChannel[2] = Sync;
    ReefAngel.DCPump.ExpansionChannel[3] = AntiSync;
// Add random mode if we set to Mode to Custom in portal
static int rmode;
const int Else=16;
changeMode=false;
  //else
  //ReefAngel.Relay.On(Port3);
  } else {
} else {
////////// Variables used for all channels
// What day in the acclimation cycle it is
  byte acclDuration = InternalMemory.read(Mem_B_AcclDuration);
// Acclimation Duration in days
  byte startPercent = InternalMemory.read(Mem_B_SlopeStart);
// Normal start% being used by all 3 channels
ReefAngel.CustomVar[Var_AcclDay]=acclDay;
////////// Blue Channel Variables
  byte acclStartEndBlue = InternalMemory.read(Mem_B_AcclStartEndBlue);
// Starting End% for Acclimation cycle
  float acclendPercentBlue = InternalMemory.read(Mem_B_SlopeEndBlue);
// Your target Blue end% once acclimation is complete
////////// Blue Channel Formula
  float acclPercentPerDayBlue = (acclendPercentBlue - acclStartEndBlue) / acclDuration;
// How much your Blue end% rises per acclimation day
  float acclFactorBlue = acclDay * acclPercentPerDayBlue;
// endPercentBlue will be offset by this much. If acclDay = 0 then this value will be 0
  byte endPercentBlue = acclendPercentBlue - acclFactorBlue;
// Your final Blue end% for the day
////////// White Channel Variables
  byte acclStartEndWhite = InternalMemory.read(Mem_B_AcclStartEndWhite);
  float acclEndPercentWhite = InternalMemory.read(Mem_B_SlopeEndWhite);
// Your target White end% once acclimation is complete
////////// White Channel Formula
  float acclPercentPerDayWhite= (acclEndPercentWhite - acclStartEndWhite) / acclDuration;
// How much your White end% rises per acclimation day
  float acclFactorWhite = acclDay * acclPercentPerDayWhite;
// endPercentWhite will be offset by this much. If acclDay = 0 then this value will be 0
  byte endPercentWhite = acclEndPercentWhite - acclFactorWhite;
// At the end of the day, we need to decrement the acclimation counter.
  static boolean acclCounterReady=false; // We need a boolean so we only do this once per day
  if (now()%SECS_PER_DAY!=0) acclCounterReady=true; // If it's not midnight we'll get the boolean ready
  if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) { // It's midnight, our bool is true and acclDay is more than 0
    acclDay--; // Reduce the counter
    acclCounterReady=false; // Reset the boolean flag
    InternalMemory.write(Mem_B_AcclDay,acclDay); // Update memory
    // handle updating sunrise and sunset values
    sl.CheckAndUpdate();
    //sl.SetOffset(10,0,10,0); // rise_hour, rise_seconds, set_hour, set_seconds
    ReefAngel.Portal( "89delta" );
  // Calculate your regular sunrise/sunset PWM value
  ActinicPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentBlue,120,(MoonPhase()/3));
  DaylightPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentWhite,120,DaylightPWMValue);
  //ActinicPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),0,90,120,(MoonPhase()/3));
  //DaylightPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),0,90,120,DaylightPWMValue);
  CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(8,30)
#define End_Cloud_Before NumMins(18,30)
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
    ReefAngel.LCD.Clear(255,0,62,132,132);
      int x=0;
      if ((cloudstart/60)>=10) x=11; else x=17;
      ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart/60));
      if ((cloudstart%60)>=10) x=29; else x=35;
      ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart%60));
    ReefAngel.LCD.DrawText(0,255,90,62,cloudduration);
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
      ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))/60));
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
      ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Posted: Sun Jul 20, 2014 6:08 am
Move ReefAngel.Relay.On(Port3); to the top of the loop() function instead of setup().
Essentially you are turning it off during feeding mode and nothing is turning it back on. You may also want to use DelayedOn instead of On also to prevent an overflow.
