Error uploading. (please help)
Posted: Mon Aug 04, 2014 10:57 pm
I am trying to get an older basic RA up and running on a quarantine tank.
I am getting "Error uploading." with the following details:
Watchdog Timer
Version Menu
Relay Expansion Module
Number of Relay Expansion Modules: 1
Standard Menu
Binary sketch size: 27,752 bytes (of a 30,720 byte maximum)
E:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CE:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM1 -b57600 -D -V -Uflash:w:C:\Users\ORBITO~1\AppData\Local\Temp\build8438675645450573292.tmp\sketch_aug04b.cpp.hex:i
System wide configuration file is "E:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM1
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x0c
avrdude done. Thank you.
