Which relay box ports stay on when head reboots?
Posted: Wed Aug 13, 2014 4:33 pm
by AlanM
Like the subject says. I should have checked this before I plugged everything in, but do the relay box ports stay on if it loses contact with the head unit if they're configured as always on ports in setup()?
I'd kind of like my return pump to keep going when I load new code. Don't care so much about the rest of the stuff.
Re: Which relay box ports stay on when head reboots?
Posted: Wed Aug 13, 2014 6:25 pm
by psirex
I believe unless the port is set to 'always on' it will reboot when the head controller does.
Super Samsung Device
Posted: Thu Aug 14, 2014 4:22 am
by Smotz
I think they all briefly power cycle
Posted: Thu Aug 14, 2014 5:23 am
by howaboutme
It's instantaneous (at least for me). I don't even notice any flickering w/ my lights (plugged into the port) or my pump. The only part that I notice is my powerhead (jebao). It will for a split second start up at 100% power before the code kicks in and drops it down.
Posted: Thu Aug 14, 2014 5:43 am
Ports maintain their status. But if they lose connectivity to the head unit they will all turn off. The future wireless relay box Roberto mentioned will have fallback settings.
Posted: Thu Aug 14, 2014 1:54 pm
by AlanM
OK. My SOP at the moment is to disconnect the head unit near the sump, carry it upstairs to the computer, program it, and carry it back downstairs. Lee says that they will all turn off. Jack says that his stay on. Which is it?
I do know that the dimming expansion keeps the lights on if the head unit is disconnected and the pumps keep running if the head unit is disconnected from the relay box. They are connected to the dimming ports on the relay box. I assumed that since PWM values didn't change, but they didn't turn off either then the relays would be the same way.
Posted: Thu Aug 14, 2014 1:57 pm
by howaboutme
Oh, I didn't realize you were disconnecting your head unit. I must have missed that. I was assuming you had the head unit attached but uploading code. I use a super long USB extension......probably not an option for you since you have a floor to contend with.
Posted: Thu Aug 14, 2014 2:39 pm
Get the Bluetooth attachment
Posted: Thu Aug 14, 2014 3:15 pm
Get a cheap netbook
Posted: Thu Aug 14, 2014 4:02 pm
by cosmith71
rimai wrote:Get the Bluetooth attachment
This will change your life.
Posted: Thu Aug 14, 2014 4:26 pm
by AlanM
I would have gotten that when I bought the stuff, but it isnt on your site for purchase that I can see. Is it a special order?
Posted: Thu Aug 14, 2014 8:43 pm
Yes, PM me if you want one.
Posted: Fri Aug 15, 2014 12:52 pm
by AlanM
Will do, thanks.
Posted: Fri Aug 15, 2014 4:42 pm
by Sacohen
One of the best modules you will get.
I love my BT.
Posted: Fri Aug 22, 2014 5:29 pm
by AlanM
OK. I got one, got it paired, figured out which one was outgoing serial, and am ready to send new code to the unit. So you say it doesn't drop the relay box outlets except for a brief smidge when it reboots?
Posted: Fri Aug 22, 2014 5:41 pm
by Sacohen
That's correct.
I don't even recall mine dropping at all.
Posted: Fri Aug 22, 2014 6:58 pm
The relays will stay in their existing state while its loading and rebooting. The only blip you'll get is the difference between your current state, state of your setup and loop() configurations
Posted: Fri Aug 22, 2014 8:03 pm
by AlanM
Great. That is what I hoped.
Posted: Sat Aug 23, 2014 9:23 am
by AlanM
Bluetooth worked perfectly!
I didnt notice any blip at all when loading new code. Head unit is in the basement on a wall and bluetooth is upstairs and 20 feet away, and had no problems. It loaded slower than cable. Maybe because I had default of 9600 baud or something?
Anyway, this thing removes the one big limitation for me to this device. I think it should get more prominent exposure on the site because it is so useful.
Posted: Mon Aug 25, 2014 5:49 pm
by wolffman64
I didn't know the module existed... How much is it?
Posted: Sat Dec 13, 2014 9:39 am
by bigHUN
will the BT do monitoring as well or only loading codes?
Posted: Sat Dec 13, 2014 10:15 am
just loading code.
