Reading Energy Use
Posted: Fri Aug 15, 2014 6:50 pm
Is there anyway to view how much energy is being consumed by equipment plugged into relays?
https://forum.reefangel.com/
Could we not use a CT on the power wire with the proper code?lnevo wrote:We could probably do something where we log the amount of time a port is on and track it based on a set wattage or somethingIt wouldn't be actual usage, but it could be good if we wanted to get some idea the amount of power being used...
Sent from my SCH-I510 using Tapatalk 2lnevo wrote:Whats a CT?
Either or both. But remember it can only go around 1 wire, the hot. If you run a hot and neutral through it the flux will cancel each other out. Causing a 0 reading.lnevo wrote:So it sounds like this is something we can hook to the IO board and then clamp around the incoming power to the relay box and measure overall power? Or to individual outlets..?
Yes. But you could get a weather proof box and cover. And make your taps in there with the proper wire connectors. Would be no worse than the taps behind your electrical outlet.lnevo wrote:Ahh so it needs to be integrated then inside the relay box or stripping your power plug (no thanks)
Roberto what do you say? Next gen relay box?
+1 That's exactly what I was thinking. Just make an inline box that plugs into the wall that has an outlet for the relay box. Very interesting add-on idea here though. I might have to check into this when I have a bit more time.johniii wrote:Yes. But you could get a weather proof box and cover. And make your taps in there with the proper wire connectors. Would be no worse than the taps behind your electrical outlet.lnevo wrote:Ahh so it needs to be integrated then inside the relay box or stripping your power plug (no thanks)
Even with total amps our loads are pretty constant. You would be able to tell when a heater comes on or if something is amiss by a simple trend graph like web chart. What is the benefit of having it on each individual outletRodasphoto wrote:Apex has it on each outlet of the relay. It would be nice to incorporate that same feature. For the rest of us total amps would be easier.
See what piece of equipment is being an energy hog to plan for future upgrades. To see if an individual piece of equipment is working.johniii wrote:Even with total amps our loads are pretty constant. You would be able to tell when a heater comes on or if something is amiss by a simple trend graph like web chart. What is the benefit of having it on each individual outletRodasphoto wrote:Apex has it on each outlet of the relay. It would be nice to incorporate that same feature. For the rest of us total amps would be easier.
