Dosing pump programming.
Posted: Tue Aug 19, 2014 10:42 am
Hello all. I've done a lot of lurking, searching, and copying of code but this is my first post because I just don't have enough knowledge to figure this out. I'm struggling with programming my dosing pumps. I generated the first code for my RA using the wizard with the option where values are read from memory that is accessible via Wi-Fi interface. I saw a snippet on here that only let the alk pump run when the pH was below a certain value. So, to test, I tried to turn the pump on every hour, 5 second offset, for 2 seconds.
So, I commented out this line:
// ReefAngel.DosingPumpRepeat2( Port8 );
And added:
if (ReefAngel. Params. PH < 835) //my code does not have the extra spaces but it wouldn't let me post otherwise.
ReefAngel.DosingPumpRepeat(Port8,5,60,2);
ReefAngel.Relay.Off(Port8);
I kept the dose low for testing. I monitored the system for the rest of the day. nothing seemed suspicious. Luckily, I had less than a quart left in the alk bottle because at around 3am I got a text telling me my pH was over 3.6 and all the alk had been pumped into the sump. Hearty livestock I guess cause nothing died. As I said I'm at a loss. Is there something that gets set up by the wizard that is overriding my modifications? I tried playing with just the ReefAngel.DosingPumpRepeat command, by changing the offset to 0 and running it every minute and it would run, (or not), as expected when I adjusted the pH conditional. So, the format of the code there seems correct. Help!
Here's all of the program. Real newbe here so feel free to comment about any aspect of this program not just my dosing pump problem.
And added:
ReefAngel.FeedingModePorts = Port4Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.DayLights( Port2 );
ReefAngel.StandardLights(Port3,18,0,8,0); // Lights on at 6:00pm and off at 8:00am
ReefAngel.Relay.DelayedOn( Port6 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.RF.UseMemory=true;
if (ReefAngel. Params. PH < 850)
//Moonlight Phase 6pm-8am (CH3= Daylight CH4=Actinic)
if ( (hour() >=8) && (hour() <18) )
ReefAngel.PWM.SetActinic( (0) );
ReefAngel.Portal( "waucedah_joe","xxxxxxx" );
