Problem with RA LED and PMW out
Posted: Tue Dec 06, 2011 12:07 am
by dhave
Hi,
i've just received RA controller here, in italy, and started to install it. I've purchesed also new RA led moonlight.
I install the led to the actnic pmw output and set up dawn-dusk time (DEMO software).
The led turn on, but with "flashing" effect. To stop it i put the pmw power up to 100%.
It start working properly.
Anyway, after dusk time the led turn off. So i change time to use them on night (dawn at 10pm, dusk at 10am) but it seems like controller keep in mind the old time configuration and keep running it. Also turning power off and start again, the led flash on during startup, then turn off immediately.
On log record is indicated moonligh main plug is on, but dawn-dusk time is in "day" time.
There is anyway to clear the log?
What is going on?
Re: Problem with RA LED and PMW out
Posted: Tue Dec 06, 2011 5:01 am
by dhave
EDIT:
The problem seems to be AM-PM setting.
Today, 12.30 PM, if i set dawn 11.00 AM and dusk 01.00 AM the led shut off.
If i set dawn 11.00 AM and dusk 11.00PM they turn on.
