Wp 25 code
Posted: Sun Sep 21, 2014 9:28 am
by mask0017
Hi found this code for switch wave modes and cant get it too work can anybody help me?
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 285 );
ReefAngel.DCPump.DaylightChannel=Sync;
ReefAngel.StandardATO( Port1,120 );
ReefAngel.Relay.DelayedOn( Port2,5 );
ReefAngel.StandardHeater( Port3,252,255 );
ReefAngel.StandardLights( Port4,20,0,8,0 );
ReefAngel.StandardLights( Port6,8,10,19,50 );
ReefAngel.StandardLights( Port7,8,5,19,55 );
if (hour()<12)
ReefAngel.StandardLights(Port5, 6, 0, 8, 5);
ReefAngel.StandardLights(Port5, 18, 0, 20, 5);
if (hour()>=8 && hour()<12)
ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) ); // Tidal Swell at 60% on sync mode
else if (hour()>=12 && hour()<16)
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% + - 20 on sync mode
else if (hour()>=16 && hour()<17)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(75,90,2000,true) ); // Nutrient Transport on sync mode
else if (hour()>=17 && hour()<20)
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 75% + - 20 on sync mode
else if (hour()>=20 && hour()<00)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,10,true) ); // Long pulse at 40% with 10s pulse on sync mode
ReefAngel.Portal( "mask0017" );
Re: Wp 25 code
Posted: Sun Sep 21, 2014 10:00 am
by cosmith71
What does it do now? Anything?
You might need to add ReefAngel.DCPump.UseMemory = false; at the top of your loop.
Re: Wp 25 code
Posted: Sun Sep 21, 2014 10:07 am
by cosmith71
Try this:
if (hour()<12)
Re: Wp 25 code
Posted: Sun Sep 21, 2014 10:17 am
by mask0017
Just loaded that up and it's now Constant 0,0
Before it was sitting at Reefcrest 65.10 but wasn't changing
Re: Wp 25 code
Posted: Sun Sep 21, 2014 11:33 am
by cosmith71
Is that off the Portal? I'm not sure you can go by that if you're using ReefAngel.PWM.SetDaylight to set the pumps. You'd need something like ReefAngel.DCPump.SetMode(LongPulse,40,10) for the Portal to reflect it correctly.
It's probably working correctly, you just can't tell from the Portal.
Re: Wp 25 code
Posted: Sun Sep 21, 2014 12:10 pm
cosmith71 wrote:Is that off the Portal? I'm not sure you can go by that if you're using ReefAngel.PWM.SetDaylight to set the pumps. You'd need something like ReefAngel.DCPump.SetMode(LongPulse,40,10) for the Portal to reflect it correctly.
Re: Wp 25 code
Posted: Sun Sep 21, 2014 9:18 pm
by mask0017
Pumps not running at all now ?
So are you saying to change all the lines like this .............
To this
ReefAngel.DCPump.SetMode( ReefCrestMode(80,20,true) )
Re: Wp 25 code
Posted: Mon Sep 22, 2014 3:07 am
by cosmith71
No, not exactly. When I have some time I'll try to figure it out for you unless someone else (Lee?) wants to have a go at it.
Are you sure it's not running? Did you stick your hand in front of it to check?
Re: Wp 25 code
Posted: Mon Sep 22, 2014 3:12 am
by mask0017
Yes was def not going no movement on prop at all .
Have it running with different code but just constant.
Was looking to try and get it to cycle through the modes throughout the day.
mask0017
Re: Wp 25 code
Posted: Mon Sep 22, 2014 6:12 am
The only way I can see that code not working is if you are using the wrong port. Also you can't look at the DCPump section in the portal because you're not using it. Just look at the Daylight/Actinic channels. But I don't see any reason in the code why it would not be working.
The only thing is this won't work:
You just need this:
if(hour()>=20)
But that would only affect the last mode. So actually it may have depended on what time you were testing... but even then you should have been on LongPulseMode.
The DCPump won't show any mode or speed because we aren't setting them anywhere. So that would explain why you see Constant / 0 / 0.
Re: Wp 25 code
Posted: Mon Sep 22, 2014 6:24 am
by hedrickms
Check your cables for loose wires or pins. I had that issue that stopped my pump from working. I had to look very closely as one of the wires popped out of the pin seat.
Re: Wp 25 code
Posted: Mon Sep 22, 2014 9:26 am
by mask0017
Hi
Yes cables are ok.
Loaded up this code and portal says Actinic 0% Daylight 0% Dc Pump Constant 0/0 . That was at 17:15 just after code load up Pump not going.
Although not sure what it should be doing at that time. Nutrient transport whatever that does, not sure how pumps spins for that mode
if (hour()<12)
if (hour()>=20)
Re: Wp 25 code
Posted: Mon Sep 22, 2014 9:33 am
At 17:15 you should be running ReefCrestMode
What's the longest and when you've left this code running? The forum portal charts shows a pretty good movement.
http://forum.reefangel.com/status/chart ... ilter=PWMD
Re: Wp 25 code
Posted: Mon Sep 22, 2014 9:40 am
by mask0017
Left it running during night last night. 23:00 - 07:00 That would be UK time.
Changed it this morning and have been trying different codes.
It's running the last one I put up now. Will leave it like that for a while if you would like to check
mask
Re: Wp 25 code
Posted: Mon Sep 22, 2014 10:06 am
It says your around 61% at the moment.
Re: Wp 25 code
Posted: Mon Sep 22, 2014 10:38 am
by mask0017
Yes did that here then it goes back to 0% as it is now, but pump dosn't run at all
Only does it with this code. If use wizard and set Reefcrest or any of the others pump runs fine.
mask0017
Re: Wp 25 code
Posted: Mon Sep 22, 2014 10:47 am
by mask0017
This what get most of time. If the Pic works
Re: Wp 25 code
Posted: Mon Sep 22, 2014 11:42 am
Two things. Please set your mode to "Custom" in the Internal Memory section. You have this set to ReefCrest and it could be conflicting with your override.
If that doesn't help, try changing this to None
You have it twice so I would change it in both. Let us know how it goes. It's odd the portal is reporting your speeds properly in the charts... let's see what happens when you change that.
Re: Wp 25 code
Posted: Mon Sep 22, 2014 12:06 pm
by mask0017
It did seem to be on custom.Will change the code tomoz. Night in UK just now can't get in tank room
mask
Re: Wp 25 code
Posted: Mon Sep 22, 2014 12:11 pm
The portal has not been reporting the mode being at 11 (Custom) in your charts. It's showing the last update at 12pm that it was at 2pm. This means that since your INO has the UseMemory=false that it's not being set. And since you've defined the pump as a DCPump it could be doing something unexpected. Also, you should set the duration to something sane and not 255 as it's considered an un-initialized value.
I would take the next step as changing DCPump to None in the code and see what happens. At some point we'll convert this INO to use the DCPump instead of the raw PWM commands to set what we want.
Re: Wp 25 code
Posted: Mon Sep 22, 2014 12:20 pm
Here's the code converted to use DCPump just to get that out of the way.
The only thing it doesn't do at this moment is allow you to use the portal to change it. We should see the mode and speed change properly and be reflected in the portal (just not in the Internal Memory section).
if (hour()<12)
ReefAngel.DCPump.SetMode( LongPulse,40,10 ); // Long pulse at 40% with 10s pulse on sync mode
ReefAngel.DCPump.SetMode( TidalSwell, 60, 0 ); // Tidal Swell at 60% on sync mode
ReefAngel.DCPump.SetMode( ReefCrest, 80, 0 ); // ReefCrest at 80% + - 20 on sync mode
ReefAngel.DCPump.SetMode( NutrientTransport, 90, 0 ); // Nutrient Transport on sync mode
ReefAngel.DCPump.SetMode( ReefCrest, 80, 0 ); // ReefCrest at 75% + - 20 on sync mode
if (hour()>=20)
Re: Wp 25 code
Posted: Mon Sep 22, 2014 12:32 pm
by mask0017
Thanks a lot for that. Will get it loaded up tomorrow.
Sorry for being a bit of a pest but no much idea about coding.
Be good for the likes of me if you could set different modes at time you want by the wizard.
Wizard=Easy ....... Coding = Brick wall with head stuck in it.
mask
Re: Wp 25 code
Posted: Mon Sep 22, 2014 12:40 pm
For the most part you did alright getting that chunk of code in and honestly not sure 100% the why it's not working part, except for telling it to use DCPump and then not using it. I think that's our biggest problem. Because you never say to use InternalMemory everything is getting default 0 0 0 and even though we are specifying the speeds to the Daylight channel directly, the DCPump is overriding it. I think this is the main issue and should be addressed by the above.
Re: Wp 25 code
Posted: Tue Sep 23, 2014 12:06 am
by mask0017
Have got that loaded up now. Working perfect.
That's great working exactly the way I was wanting.
Big thanks for all the help.
Only got to get a delay on the ATO port to make code finished
Something like this maybe?
ReefAngel.DelayedOn(Port1, 5);
But thought I read somewhere about delay on ATO a no go
thanks
mask
Re: Wp 25 code
Posted: Tue Sep 23, 2014 3:19 am
by cosmith71
What kind of delay are you looking for? Are you using a single or double switch ATO?
Re: Wp 25 code
Posted: Tue Sep 23, 2014 3:32 am
Yeah delayed on won't work. I'll write something up for you in a little while.
Re: Wp 25 code
Posted: Tue Sep 23, 2014 4:36 am
try this:
static unsigned long atoTimer;
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) atoTimer=now();
if (now()-atoTimer < 300) {
ReefAngel.Relay.Off(Port1);
} else {
ReefAngel.StandardATO(Port1,120);
Wp 25 code
Posted: Tue Sep 23, 2014 9:11 am
by mask0017
Hi
Colin it's a standard 2 float switch ATO, was just needing a short delay after water change/feeding mode.
Thanks for all the help with the coding Lee.
Everything seems to be working fine now. Here's finished code, may help others needing same
} else {
if (hour()<12)
if (hour()>=20)
