Log Water level
Posted: Sun Sep 28, 2014 1:37 am
by tom_swell
Hi guys,
Just wondering if there's a way i can log the water level. I have the waterlevel expansion and i was just wanting to generate some simple graphs like the default ph and Temp ones but for waterlevel. Any ideas how to do this?
Re: Log Water level
Posted: Sun Sep 28, 2014 3:06 am
by arch
Re: Log Water level
Posted: Mon Sep 29, 2014 1:29 am
by tom_swell
Cheers mate,
These are the codes I'm using right now which rely on water level. First one is for ATO and second one is too ensure pump switches off if water level gets so high:
ReefAngel.WaterLevelATO( Port6,60,88,92 );
if (ReefAngel.WaterLevel.GetLevel() >= 100) ReefAngel.Relay.Off(Port6);
My only problem is, the Water has been topped up by the ATO to 96, and it keeps on topping it up to a higher level than it should according to that code. Like i've seen it turn on when the water level is already at 94 and add water to the tank. Anyone have ideas why this is happening?
Re: Log Water level
Posted: Mon Sep 29, 2014 5:25 am
First make sure your ATO pump isn't getting a siphon. That was the issue the last time we saw this problem. Even though it was a peristaltic pump!!
Second, post your full code so we can make sure there are no other issues conflicting.
Re: Log Water level
Posted: Tue Sep 30, 2014 12:15 am
by tom_swell
Definitely not creating a siphon as the ato reservoir is below the tank and the hose output is about 8cm above water level so there's no way it could create a siphon and even if it did, that would result in water flowing down into the reservoir leaving a lower water level. My issue is that mater level is too high for some reason.
Here's my full code:
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.CustomLabels[0]="Left Wavemaker";
ReefAngel.CustomLabels[1]="Right Wavemaker";
ReefAngel.CustomLabels[2]="Heater";
ReefAngel.CustomLabels[3]="Light";
ReefAngel.CustomLabels[4]="Skimmer";
ReefAngel.CustomLabels[5]="ATO";
ReefAngel.CustomLabels[6]="Unused";
ReefAngel.CustomLabels[7]="Unused";
ReefAngel.StandardHeater( Port3,240,250 );
ReefAngel.Portal( "tom_swell" );
Thanks a lot,
Tom
Re: Log Water level
Posted: Tue Sep 30, 2014 7:59 am
I don't see anything wrong with it.
Can we try something different?
Try this code instead:
if (ReefAngel.WaterLevel.GetLevel() > 0 && ReefAngel.WaterLevel.GetLevel() <= 88)
ReefAngel.Relay.On(Port6);
if (ReefAngel.WaterLevel.GetLevel() >= 92)
Re: Log Water level
Posted: Tue Sep 30, 2014 3:14 pm
by tom_swell
Hi Roberto, does that just go where the old ATO code was or should it go in the custom code section? Thanks for all your help!
Re: Log Water level
Posted: Tue Sep 30, 2014 4:11 pm
Yes, remove the old ATO function and add this code.
